August 2nd, 2011, 11:50 AM | #1 |
Join Date: Oct 2010 Motorcycle(s): 09 ninja 250 Posts: 131
HELP bike won't start after crash
I recently crash my bike and im trying to fix it right now. The bike doesn't starts, battery seem to be fully charged, bike is probably still in 3 or 4 gear since the drop, and i cant put it back to neutral because the foot peg broke off. I put the key in, hit the red switch, hold in the clutch and push start and NOTHING. No sparks, no noise, nothing. All the lights next to the tachometer turn on, brake light still work fine, signals light doesn't turn on.
more info on my bike condition: right front signal is broken, left foot peg broke so gear shifter is not working. It was a pretty hard crash on palomar mtn. and when the guys help lifting my bike up, i saw gasoline poured out. I checked the gas tank, doesnt seen like there's any crack at all. I appreciate any help i can get right now. UPDATE: So thanks to you guys, im able to start my bike now after shifting it back to neutral. I switched out my Yoshi slip on and put back the original pipe, removed rearset adjuster. Now i realized that my front rim is badly damaged
ride it like you stole it! Last futzed with by maxwellca21; August 5th, 2011 at 04:13 PM. |
August 2nd, 2011, 11:55 AM | #2 |
If the lights are on, yet the starter doesn't even click when pressed, one of the safety interlocks is the cause. Could be the kill switch, the clutch interlock, the kickstand interlock, or the neutral interlock. In this case you're saying that it's not in neutral, so that limits it to 3.
August 2nd, 2011, 11:56 AM | #3 |
Hmmm! ok i think i understand a little better now... maybe your clutch trigger switch isn't hitting? or maybe your kickstand sensor switch? and since you can't get it into neutral it won't let you start?
edit: ahh alex beat me to it
August 2nd, 2011, 11:59 AM | #4 |
i see just the mount has broken on your shifter... you might be able to get it into neutral by manually pulling on the rod, though it might be hard
August 2nd, 2011, 12:00 PM | #5 |
if you have a way to come over i have a spare oem left rearset you can have, or if you can wait a little while i can come over and check it out with you
August 2nd, 2011, 07:28 PM | #6 |
thanks man. let me know when you r free.
ride it like you stole it! |
August 2nd, 2011, 07:30 PM | #7 | |
August 2nd, 2011, 08:18 PM | #8 |
There is a plunger near the clutch lever, that sticks out when the clutch is pulled, and when the clutch is released it pushes the little plastic plunger back in. If it's not working correctly, it's possible that the bike doesn't know your clutch is pulled in, and therefore will only start if it's in neutral.
The neutral sensor is internal to the transmission (not sure how to check it visually, if it's even possible). Basically, it's the sensor that pops on the green neutral light on the dash. If that isn't working, the bike never knows that it's in neutral, so the clutch needs to be pulled in to start. If the kickstand is loose, springs off etc., I'd take a close look at the kickstand sensor.
August 3rd, 2011, 12:15 AM | #9 | |
August 3rd, 2011, 12:49 AM | #10 | |
Alex, this thread is in the wrong location. OP has an 09. Just FYI. |
August 3rd, 2011, 05:52 AM | #11 |
Your clutch interlock isn't working, make sure that plunger near the clutch lever freely goes in and out.
August 3rd, 2011, 05:52 AM | #12 |
/moved to new-gen tech
September 5th, 2011, 02:53 PM | #13 |
Where do I find the clutch switch? My bike only starts in neutral for me after falling in the dirt. It fell in the right side so there is nothing wrong at the lever end.
September 5th, 2011, 04:21 PM | #14 |
How many threads you plan to bump with this?
September 5th, 2011, 05:04 PM | #15 |
They're all surprisingly recent (last several months) and none have that specific bit of information I'm looking for yet. The participants are likely looking at these threads and not mine and it's not something mentioned in my OP or title, so: The more, the merrier (though I'm done now).
It certainly got me an answer or two so far! I was ready to let my thread die and continue the conversation in an existing thread as soon as I heard "clutch safety switch" in the very first reply. Next step was to search for exactly that and then to ask because none of the results mentioned the location. My question in this thread was really asking where the wiring was routed because I very much doubt that a right-side drop physically damaged anything on the left bar and also I have reason to suspect other electrical issues (gauge light going out right when this started). Thanks for everything. |
Help!!!!!!!! - bike won't start | auntymunga | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2014 06:54 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
Bike won't start | sLick415 | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 4th, 2013 11:38 PM |
Bike won't start after crash??? | Jono | 1986 - 2007 Ninja 250R Tech Talk | 31 | January 12th, 2012 10:23 AM |
bike won't start :/ | SephiaSputnik | 1986 - 2007 Ninja 250R Tech Talk | 20 | March 12th, 2010 02:40 PM |
