Old October 27th, 2022, 08:06 AM   #1
[cycleworld.com] - 2023 BMW R1250 R First Look
BMW’s boxer-powered all-rounder gets a nice list of minor improvements, no change to list price.
The 2023 BMW R 1250 R in Style Sport Racing Blue Metallic. (BMW/)It seems BMW won’t be messing too much with a good thing this year, as their R 1250 R will get only small but significant quality-of-life changes for 2023. The most BMW of BMW motorcycles will still be powered by a boxer twin, the same ShiftCam-equipped engine with the same claimed 136 horsepower and 105 pound-feet of torque it’s had since its inception, running on the same ParaLever suspension.
The 2023 R 1250 R now benefits from BMW Motorrad ABS Pro as standard equipment. (BMW/)The changes are almost completely electronic. Dynamic Traction Control (DTC), Dynamic Brake Control (DBC), and BMW Motorrad ABS Pro are now standard, and a third riding mode, Eco, has been added to the bike’s existing Road and Rain modes. Having ABS Pro, a lean-sensitive anti-lock system, as standard is arguably the best part of the new improvements. Perhaps the most dubious is Eco mode, in which as BMW says, “the rider is encouraged to ride as fuel-efficiently as possible with a soft throttle curve and moderate engine torque limitation” while aided by green feedback from the color TFT display, which in a bit of mixed messaging BMW calls the Sport Core screen. The only visible upgrade is a switch to LED turn signals, another nice touch.
The R 1250 R in standard Ice Grey. (BMW/)Other new bits are optional, and include an adaptive turning headlight that switches on additional LEDs according to lean angle, an attractive passenger seat cover, and spoked wheels.
Close-up on the R 1250 R’s new optional solo seat kit. (BMW/)Happily there is no change to the R 1250 R’s MSRP, which remains at $14,995. The 2023 model will be available standard in Ice Grey, with Triple Black and Style Sport Racing Blue Metallic as color options.
The 2023 R1250 R in Triple Black. (BMW/)2023 BMW R 1250 R Specs
MSRP:$14,995Engine:Liquid-cooled 2-cylinder, 4-stroke boxer engine with two overhead, spur-gear driven camshafts, counterbalance shaftDisplacement:1254ccBore x Stroke:102.5 x 76.0 mmCompression Ratio:12.5:1Transmission/Final Drive:6-speed/shaftClaimed Horsepower:136 hp @ 7,750 rpmClaimed Torque:105 lb.-ft. @ 6,250 rpmFuel System:Electronic fuel injectionClutch:Wet, multi-disc slipper; hydraulic operationEngine Management/Ignition:Ride-by-wireFrame:Two-section frame with bolt-on rear section and load-bearing engineFront Suspension:45mm inverted fork, fully adjustable; 5.5 in. travelRear Suspension:BMW Paralever, fully adjustable, 5.5 in. travelFront Brake:Twin 320 mm floating disks, 4-piston radial calipersRear Brake:Single 276 mm disk, 2-piston floating caliperWheels, Front/Rear:Cast aluminum; 3.5 x 17in. / 5.5 x 17in.Tires, Front/Rear:120/70 ZR17 / 180/55 ZR17Rake/Trail:27.7°/4.9 in.Wheelbase:59.6 in.Ground Clearance:n/aSeat Height:32.3 standard, 29.9 – 33.1 possibleFuel Capacity:4.8 gal.Claim Wet Weight:527 lb.Contact:bmwmotorcycles.com
[cycleworld.com] - 2023 BMW M 1000 R First Look Ninjette Newsbot Motorcycling News 0 October 11th, 2022 04:13 PM
[cycleworld.com] - 2023 BMW M 1000 RR Ninjette Newsbot Motorcycling News 0 October 11th, 2022 03:35 PM
[cycleworld.com] - 2023 BMW S 1000 RR First Look Ninjette Newsbot Motorcycling News 0 September 29th, 2022 02:18 PM
[motorcycle.com] - 2019 BMW R1250 GS/ R1250 GS Adventure First Ride Review Ninjette Newsbot Motorcycling News 0 March 9th, 2019 09:52 AM
[visordown.com] - New engine for 2019 BMW R1250 GS and R1250 RT Ninjette Newsbot Motorcycling News 0 September 17th, 2018 11:46 AM
