October 27th, 2022, 09:25 AM | #1 |
[roadracingworld.com] - KTM Launches Refined 450 SMR Supermoto Track Bike
2023 KTM 450 SMR: TAKE THE LONG SLIDE TO SUPERIORITY * MURRIETA,*Calif. – KTM North America, Inc. introduces the 2023 KTM 450 SMR, one of the company’s finest expressions of […]
The post KTM Launches Refined 450 SMR Supermoto Track Bike appeared first on Roadracing World Magazine | Motorcycle Riding, Racing & Tech News. 2023 KTM 450 SMR: TAKE THE LONG SLIDE TO SUPERIORITY * MURRIETA,*Calif. – KTM North America, Inc. introduces the 2023 KTM 450 SMR, one of the company’s finest expressions of pure READY TO RACE machinery. Even at a glimpse, the latest version of this competition Supermoto weapon reveals a bike purposely built to annihilate the asphalt. In a discipline where tenths of a second and fractions of an inch can make all the difference, the precision and sheer racing intent behind the 2023 KTM 450 SMR are exactly what any Supermoto fan or racer need. The innovations start with the refined hydro-formed, laser-cut and robot-welded frame. Front-end focus and confidence, along with rear-end stability, define everything that is fast on the Supermoto circuit. KTM has altered longitudinal and torsional flex through frame wall thickness and bracing to make sure that feedback and control are on-point to satisfy any rider – from novice to world championship-level racers. At the rear, a revised shock mount enhances energy absorption and straight-line stability for 2023. The anti-squat behavior translates to better acceleration and corner exit speed, courtesy of its repositioned rotational masses and an all-new, shorter shock body. New, wider foot pegs with tucked in pivot points enhance the feeling that the 2023 KTM 450 SMR can be gripped, turned and pushed however hard the rider wants. The polyamide reinforced aluminum two-piece subframe is another ingredient for overall greater handling with the bonus of superb strength. Rider flow out on the track comes effortlessly working through the high-grade aluminum CNC-machined triple clamps, which are newly designed with increased grip surface for less handlebar twist. A 2023-model KTM 450 SMR Supermoto track bike at rest. Photo by Philip Platzer, courtesy KTM.Sliding into turns has never felt easier thanks to the added reassurance delivered by the expertly calculated flex character from the new, diecast aluminum swingarm, new 22 mm rear axle and the latest generation of WP XACT Suspension. XACT 48 mm forks with AER technology have a split-damping function, simple toolless adjusters and are set up for Supermoto domination right out of the crate. Balancing the front-end performance is the new shorter, lighter WP XACT rear shock (shorter but with the same amount of travel), which is fully optimized for tarmac and features several significant upgrades to enable advanced damping characteristics. The new WP XACT shock is the most progressive and capable system seen on a KTM Supermoto machine yet. Calculated millimeters on corner entry are made possible by a high-powered 4-piston Brembo brake system clamping down on a 310 mm front disc. A 220 mm disc and single piston caliper will bring the rear end around nicely while it’s complimented by the SUTER anti-hopping clutch and Brembo hydraulics that will let riders drift all the way ‘til they shift. Once the Metzeler Racetec SM K1 tires (with a large usage window and rapid warm-up times) have been abused into the apex, the unmistakable firepower of the 2023 KTM 450 SMR gets everything winding forward. The new SOHC engine is designed with mass centralization as the goal and blasts out massive power and torque from a physically smaller overall package compared to the previous edition. The engine itself has been tilted back and the sprocket dropped by 3 mm with new cylinder internals and crankshaft optimization as other markers of the 2023 set-up. PANKL Racing Systems have supplied a redesigned 5-speed gearbox with a new transmission ratio. To make quick work of shifting, the fresh Quickshift sensor on the shift drum allows for clutch-less upshifts from second to fifth gear (this can also be disabled through the handlebar switch). The Keihin Engine Management System will administer the traction control, launch control and Quickshift actions and the ability to flick between two selectable engine maps. Throwing the whole package into place on-track is now simpler with new ergonomics and the sculpted rider ‘triangle’ that permits even better contact points between motorcycle and user. There won’t be a better or harder-looking bike on the track than the 2023 KTM 450 SMR. The 1990s-derived splash of purple adds to the READY TO RACE graphic vibe together with the flat orange seat and white tail. 2023 KTM 450 SMR TECHNICAL HIGHLIGHTS // Acute new anti-squat frame concept for unbeatable agility, sensitivity and stability // Lighter and more durable 63 hp engine package for peerless power to weight ratio // New generation advanced and easy-adjusting WP Suspension // Searing braking components from Brembo // Performance-led parts from foot pegs, compact exhaust system, electronics, wheels and tires // Improved ergonomics to accentuate agility and centralization: better lap times // Unmistakable race-orientated graphics and one of KTM’s best color schemes yet The 2023 KTM 450 SMR will arrive at authorized KTM dealer floors from November 2022 onwards. For more information, visit ktm.com. The post KTM Launches Refined 450 SMR Supermoto Track Bike appeared first on Roadracing World Magazine | Motorcycle Riding, Racing & Tech News.
[visordown.com] - KTM aims for stability and control with 2023 450 SMR supermoto | Ninjette Newsbot | Motorcycling News | 0 | May 31st, 2022 10:40 AM |
[visordown.com] - KTM 450 SMR supermoto gains some minor updates for 2022 | Ninjette Newsbot | Motorcycling News | 0 | September 9th, 2021 03:31 AM |
[roadracingworld.com] - KTM Updates Look Of 450 SMR For 2022 | Ninjette Newsbot | Motorcycling News | 0 | September 7th, 2021 05:01 PM |
[roadracingworld.com] - 2021 KTM 450 SMR: Ready To Race Supermoto | Ninjette Newsbot | Motorcycling News | 0 | February 16th, 2021 05:43 PM |
[roadracingworld.com] - AMA Supermoto: Fillmore Rides KTM 450 SMR To Championship | Ninjette Newsbot | Motorcycling News | 0 | November 10th, 2020 11:01 AM |
