June 12th, 2008, 01:06 PM | #1 |
[motorcyclistonline.com - first rides] - Moto Guzzi California Vintage - First Ride
Retro, Metro Euro-Tourer My past dalliances with Moto Guzzi cruisers have generally been pleasant affairs, so when I got wind of the California Vintage, I was pretty keen to pile on the miles. Based on appearance alone, the new touring mount looked like a blast to ride. Introduced to the European market in 2006, this touring version of the venerable California custom made its way to the USA last year. The California has been one of Guzzi's most reliable sellers for decades, and because the long-struggling Italian manufacturer traditionally had only enough resources to gussy up a few models at a time, this one took on the role of Euro-cruiser as much by accident as by design. Now that Piaggio is signing the checks, however, Guzzi is living large. The California Vintage is shot through with styling cues cribbed from the past, such as the spoked wheels, chromed steel fenders and classic black paint with white pinstripes. Touring accoutrements include the chrome-rimmed saddlebags, luggage rack and medium-height windshield framed by auxiliary fog lights. The Vintage got some mechanical upgrades as well, not least the 1064cc V-twin swiped from the Breva 1100. Newer bits include a less shaky crankcase, lighter pistons, an upgraded hydraulic valve train and fuel injection, which helps the bike achieve Euro 3 compliancy. Settling atop the bike's 30-inch-high saddle, the slightly pulled-back wide bar is well within reach. But beneath the urbane faade lie Marquis de Sade ergos: Awkward floorboards folded my knees nearly to my rib cage (and I'm a stubby guy), while the transverse cylinders stymied any attempt to stretch my legs. Sub-6-footers can probably live with the seating position, but anyone with an inseam over 31 inches will cry uncle. Guzzi says this arrangement maximizes cornering clearance, but I'm not buying it-the floorboards could easily be an inch lower. Once underway, the loping 90-degree V-twin ushered me down the road with little drama and minimal shaft effect. The claimed 74 bhp is adequate for casual cruising, and in the twisties the Vintage is much more agile than most other bikes of its ilk. Conservative steering geometry translates into good stability and neutral handling. The engine's loping cadence felt odd below 4000 rpm, partly due to tall gearing. Passing usually entailed a downshift, which wasn't always a simple proposition because the heel/toe shifter was maladjusted. While I could generally gear up by pushing down with my heel, the front of the lever was too close to the floorboard to hook my toe underneath. I also had to lift my right foot clear of the 'board to depress the brake pedal; forget about modulating it. Moreover, the gearbox displayed vague action, especially when trying to click into neutral. On the road, the Magneti Marelli sequential fuel injection was about on par, though there was some noticeable on/off hesitation and on a few cold mornings the engine proved hard to start. The conventional Marzocchi fork soaked up big hits admirably, but the standard-issue, preload-adjustable twin shocks occasionally dropped the ball on sharper whacks. No question the Brembo brakes are up to snuff, even though I'm usually not a fan of linked brakes (one front disc is activated by the rear brake pedal). I routinely got upward of 35 mpg, so the 5-gallon fuel tank should easily stretch close to 200 miles. As for the luggage, while the saddlebags are attractively shaped, nicely integrated, waterproof and fairly capacious, I had trouble aligning the latches for secure closure. In the end, the Vintage is a well-intentioned blend of retro looks and modern function. Going to California, it turns out, doesn't require an aching heart after all. Tech Spec Evolution A stylized take on the original V7 California ridden by '70s LAPD motor cops. Rivals With its Italian styling and transverse 90-degree V-twin, it's arguably in a class of its own. TECH Price: $14,990 Engine type: a-c, 90-deg. V-twin Valve train: OHV, hydraulic adj. Displacement: 1064cc Bore x stroke: 92.0 x 80.0mm Compression: 9.8:1 Fuel system: EFI Clutch: Dry, single-plate Transmission: 5-speed Claimed horsepower: 74 bhp @ 6400 rpm Claimed torque: 60 lb.-ft. @ 5000 rpm Frame: Tubular-steel double cradle Front suspension: 45mm Marzocchi fork with adj. compression and rebound damping Rear suspension: Twin shocks with adj. spring preload Front brake: Dual Brembo four-piston calipers, 320mm discs, linked Rear brake: Single Brembo two-piston caliper, 282mm disc, linked Front tire: 110/90-VB18 Metzeler Rear tire: 140/70-VB17 Metzeler Rake/trail: 29.0/4.6 in. Seat height: 30.7 in. Wheelbase: 61.4 in. Fuel capacity: 5.0 gal. Claimed dry weight: 580 lbs. Colors: Black/white Available: Now Warranty: 2 yrs., unlimited mi. Verdict A tastefully done retro-tourer, but its European styling and Dom Perignon price tag won't suit most Americans' Budweiser palates. Photo Gallery: Moto Guzzi California Vintage - First Ride - Motorcyclist Magazine Read More | Digg It | Add to del.icio.us Click here for full story...
[cyclenews.com] - First Ride: 2013 Moto Guzzi California 1400 Custom | Ninjette Newsbot | Motorcycling News | 0 | June 7th, 2013 01:40 PM |
[motorcyclistonline] - Moto Guzzi California | First Ride | Ninjette Newsbot | Motorcycling News | 0 | December 14th, 2012 09:30 PM |
[topix.net] - First ride! New Moto Guzzi California | Ninjette Newsbot | Motorcycling News | 0 | November 23rd, 2012 01:30 PM |
[motorcyclistonline] - 1982-2008 Moto Guzzi California | Ninjette Newsbot | Motorcycling News | 0 | February 25th, 2011 05:00 PM |
[motorcyclistonline] - Moto Guzzi California Vintage - First Ride | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 04:45 AM |
