March 25th, 2014, 06:56 AM | #1 |
Jedi on Two Wheels
Join Date: Nov 2013 Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded) Posts: 489
Installing tech specs on 08-12 Ninja.
So normally its recommended to wax and degrease your tank before installing any form of grip. But on for the 08-12 Ninjas, it doesn't go onto the tank, it goes on the plastic piece below the tank. Do I need to do any sort of special prep work still?
May the force be with you and keep your rubber side down. |
March 25th, 2014, 07:08 AM | #2 |
Blind 250 Loving Whore
If you have any protection on there like armor all or something id strip it off with IPA. Just so it sticks better.
March 25th, 2014, 09:53 PM | #3 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
I have Tech Specs on my ZX6R, CBR600RR, and Ninja 250R. I just make sure the surface is clean and dry. Then, I peel off the adhesive that comes with the Tech Specs because it's poorly made and cut. I use outdoor adhesive and put it on the Tech Specs and apply to the bike. Looks cleaner and better grip.
March 25th, 2014, 11:23 PM | #4 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150 Posts: 68
what adhesive did you use? i also have the same problem with tech spec's one
March 25th, 2014, 11:33 PM | #5 | |
March 26th, 2014, 04:55 AM | #6 |
Thanks !
March 26th, 2014, 05:18 AM | #7 | |
Join Date: Feb 2012 Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650 Posts: 275
They've been on there for an entire year with absolutely no issues. |
March 26th, 2014, 10:56 AM | #8 |
clean with soap and water until its sparkly. then clean with alcohol to get the surface super dry once the alcohol evaporates. then put the stickers on.
March 26th, 2014, 01:02 PM | #9 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
striping stuff like that, use dish washing liquid
strips stuff like wax to grease and oil |
March 27th, 2014, 03:26 PM | #10 |
Jedi on Two Wheels
I just installed em today. I used rubbing alcohol to clean it down, washed my hands, and used a hair dryer to heat it up like the recommended. Fit on the plastic pieces just fine. It said to give it 12 hours to stick, which is about when Ill be off to VA for the day. So it will get a thorough test!
March 27th, 2014, 04:04 PM | #11 |
March 27th, 2014, 06:31 PM | #12 |
March 27th, 2014, 07:28 PM | #13 |
Ohhh! Rubbing alcohol. Derp.
Installing a 49-state tank on a ca model 08 ninja 250 | eramz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 12th, 2014 09:03 AM |
[faster and faster] - Ariel Ace: Official high-res pics, tech specs, details | Ninjette Newsbot | Motorcycling News | 0 | July 4th, 2014 08:57 AM |
[faster and faster] - 2012 Aprilia Dorsoduro 1200: High-res pics, tech specs | Ninjette Newsbot | Motorcycling News | 0 | March 8th, 2012 08:20 PM |
Tech specs tank grip | randomwalk101 | 2008 - 2012 Ninja 250R Farkles | 14 | February 6th, 2012 08:13 PM |
[hell for leather] - 2010 Alpinestars Tech 8: Tech 10 specs, Tech 8 sole | Ninjette Newsbot | Motorcycling News | 0 | December 28th, 2009 08:10 PM |
