Old May 3rd, 2013, 02:10 PM   #1
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
replace wheel bearings
Bought a wheel from ebay and want to replace the bearings any tips?
THE GOOD LIFE
cuz is offline   Reply With Quote
Old May 3rd, 2013, 03:07 PM   #2
tap the old ones out from the opposite side. best to press the new ones in by the outer race, but tapping them in with a large socket on the outer race works too... go slow so you dont put it in crooked.
Old May 3rd, 2013, 03:44 PM   #3
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Put the bearings in the freezer to help shink them. It will make it easier to put in and once they come up to temp they are good to go.
EDIT: As mgentz below my post has pointed out....over night.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old May 3rd, 2013, 04:09 PM   #4
mgentz
Board Member
Put in the freezer overnight
Old May 3rd, 2013, 04:15 PM   #5
tooblekain
tooblekain's Avatar
Ive never experienced putting new wheel bearings in. If freezing them overnight, will it shrink enough to be able to just push them in by hand or should just a lot easier with the proper tools?
I have this tool set: http://www.harborfreight.com/10-piec...set-95853.html
Old May 3rd, 2013, 04:20 PM   #6
its really not hard... no need to freeze... here is the tool i use:
Old May 3rd, 2013, 04:27 PM   #7
cuz
cuz
cuz's Avatar
^^ lol Thats a old hammer man did you help Noah build that ark?
yea seems pretty simple just wanted a little insight before I get started
THE GOOD LIFE
Old May 3rd, 2013, 05:03 PM   #8
It is not hard to slide the new ones in if they stay perfectly perpendicular to the axis of the wheel.
There is a light press fit (interference) between the exterior ring of the bearing and the aluminum housings of the wheel, which should be conserved by shrinking the first with some cold and expanding the later with some heat.
http://www.motorcycle.com/how-to/str...ings-3405.html
http://www.dansmc.com/wheelbearing.htm
http://en.wikipedia.org/wiki/Interfe...or_contraction
http://en.wikipedia.org/wiki/Engineering_fit
When using this method, no force is needed to remove or to insert the bearings, they just fall in by their own weight.
If temperature differential is not used, the housings in the wheel will get slightly bigger after the first installations and the bearing will slide sideways first and will increase the diameter of the housings slowly but surely after several thousands of miles.
Never force or hit the interior ring of the new bearings.
Clean all the surfaces completely, no lubricants should be here.
Last futzed with by Motofool; May 4th, 2013 at 04:42 PM.
3 Rear Wheel Bearings. Where Does The 3rd Go? az3200 1986 - 2007 Ninja 250R Tech Talk 5 June 15th, 2014 07:21 AM
front wheel bearings snot 2013 - 2017 Ninja 300 Tech Talk 12 May 14th, 2014 05:57 PM
Wheel Bearings: Similar to 250? Rekognize 2013 - 2017 Ninja 300 Tech Talk 9 April 21st, 2013 06:37 AM
Full set of new double sealed wheel bearings Zim Motorcycle-related 11 April 21st, 2010 07:47 PM
