August 19th, 2013, 02:31 PM | #1 |
Join Date: Aug 2013 Motorcycle(s): 2006 ninja 250r Posts: 7
Clutch and Engine Idle Issues
hi all!
i've been trying to revamp a ninja i just got. the clutch is a bit tough to switch gears when the engine is hot though. is that normal? oftentimes, when i'm at a stop light, i can't get it into neutral after it's hot. then also... last night, my friend and i changed out the oil to a synthetic (rotella t6 as many have commented on using), changed out the front brakes. then before that, we changed out the spark plugs, i added seafoam to the tank to clean it out, and lubed the clutch cable. however, after changing the oil, the idle has gotten weird! before, it would idle fine and steady at about 1300-1400 (after we changed the sparks). now, it idles okay in neutral when i first start it up but it gets much lower and sometimes stalls when i'm in gear. anyone have any ideas? any help is appreciated. thanks! 2006 250r with about 11400 miles. previous owner took a few spills for sure. |
August 19th, 2013, 02:44 PM | #2 |
Sounds like the clutch is out of adjustment and dragging to me.
Oil change and other maintenance you did shouldn't have had any affect on the idle speed. Check the air filter also if you haven't recently. The clutch dragging would explain both of your problems. |
August 19th, 2013, 04:11 PM | #3 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Did you put enough oil in? How did you measure your oil level?
It should be between the lines when both wheels are on level ground and the bike is straight up and down.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
August 19th, 2013, 05:26 PM | #4 |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
i had the same problem once, turns out too much seafoam. made the fuel a lil to rich, new gas, problem went away.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
August 19th, 2013, 05:53 PM | #5 | |
Personally, I like using Techron Concentrate instead of Seafoam. Techron doesn't contain Alcohol, Seafoam does. |
August 20th, 2013, 08:37 AM | #6 | |
lychee - yep, we followed instructions from the wiki. it's a tiny bit high but would that matter? we tried for the upper limit but went a tiny bit too far.
jkv45 - how would i adjust the clutch dragging? Quote:
the clutch shifting problem has always occurred though, so i don't think it would have anything to do with the oil or seafoam? btw, thanks everyone!! |
August 20th, 2013, 09:24 AM | #7 | |
Use 87 octane without Ethanol any time you can. I personally will go above 87 only if I need to to get Ethanol-free. Ethanol in gas is a terrible idea IMO. You might want to completely drain the tank then add the new gas with Techron, just to confirm that the gas isn't an issue before moving on. I'd also drain the float bowls at the same time. |
August 21st, 2013, 05:25 AM | #8 | |
If so, there is too much drag with the clutch fully applied, stalling the engine when in gear and applied brakes. That also heats up the oil too much during clutch operation (less than full discs' separation). Idle may be lower now due to a change in the gap of the spark plugs (respect to the old ones). Just adjust it with hot engine. This is just a hypothesis, I can be wrong.
August 22nd, 2013, 09:54 AM | #9 | |
thanks jkv! sorry, i didn't realize the clutch dragging was just the cable adjustment. we did that though... didn't seem to help. i'll try the new tank of gas hopefully this weekend.
August 22nd, 2013, 10:31 AM | #10 |
I would inspect the whole clutch and compare each part to specs if the condition persists.
You will need a new gasket for the clutch cover, and whatever part you find damaged or worn. http://faq.ninja250.org/wiki/How_do_...ping_clutch%3F Sometimes, dents develop on the surface of the housing over which the tabs of the fiber discs slide, preventing them from separating during clutch-in, producing the similar effect of excessive drag.
August 23rd, 2013, 10:39 AM | #11 | |
August 23rd, 2013, 12:48 PM | #12 |
You are welcome, Daphne
Having Idle issues, only running on choke..??? | rubber duckie | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 14th, 2017 08:31 AM |
Idle issues - Idle is different every time I start up. | 106 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 13th, 2014 04:57 PM |
idle issues | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 9 | July 30th, 2014 03:13 PM |
Idle/running issues | SDninja | 1986 - 2007 Ninja 250R Tech Talk | 15 | August 19th, 2010 02:09 PM |
Idle issues | Gyrene | 1986 - 2007 Ninja 250R Tech Talk | 15 | May 4th, 2010 11:43 AM |
