#1 |
Join Date: Jul 2013 Motorcycle(s): 07 ninja 250r Posts: 19
Grips
Does anyone know what size handlebars I should look for in regards to new grips that I want to install? And is there a certain grip glue or adhesive I should use on the bars and throttle tubes?
#2 |
Join Date: Mar 2013 Motorcycle(s): 2011 Ninja 250 Black Posts: 30
They're 7/8 inch. I installed these Oury RGB Road grips using hairspray (even though the instructions on the packet say not to).
#3 |
#4 | |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
i need to replace mine and wouldnt mind knowing the ins and outs, maybe find me a good deal from china.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
#5 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
7/8" should see you right. have heard hairspray is a cheap alternative to grip glue.
#6 |
It's a long boring story
Join Date: Jul 2013 Motorcycle(s): 2012 Ninja 250 Posts: 167
I just use compressed air to put grips on and off. YouTube motorcycle grip air trick for details. No glue needed. If you don't have air, I have used water to slide the grip on. Just wait for it to dry. If you must use glue, hairspray acts as lube to get it on. When it dries it will be sticky like glue.
#7 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Have put tons of grips on just fold them in half put a tiny dab of spit on the inside and viola. Might take a little practice. Make sure your left side dries before riding of course.
Mods: Offset clutch pressure plate |
What's the difference between off-road grips and street grips? | psych0hans | 2008 - 2012 Ninja 250R Farkles | 3 | April 12th, 2014 07:01 AM |
DIY - Hot Grips Heated Grips Install | NathanF | 2008 - 2012 Ninja 250R Farkles | 26 | January 23rd, 2014 03:37 PM |
[motorcyclistonline] - Spider Grips Slim Line SLR Grips | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | May 2nd, 2013 04:10 PM |
