Old August 21st, 2013, 02:03 PM   #1
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
Slow leak out of the top of the petcock hose
yet another thread about fuel leaks
things i already know:
1) my petcock is bad
2) its been bad as long as ive had the bike
3) the slow leak just started
4) it is coming out of the top of the tube connected to the petcock
5) if i work the hose around it will stop
6) also need to replace the vacuum hose
so im pretty sure i need to replace the hose, and of cource i need to get my cheap ass in gear on rebuilding the petcock.
the things i need help on:
1) a good cheap petcock rebuild kit
2) the size and length of the hose
3) best kind of clamps to use on the hose
4) good cost effective fuel filter
5) @Jiggles to bust out some insurance moneys and buy me all this stuff
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old August 21st, 2013, 03:04 PM   #2
tc.young
Motorcycle(s): '89 klr 650, '00 250r
i would suggest new petcock. the rebuilds while replacing all the rubber never take for me, and still leak or leak in off position, etc. bring both hoses to napa or autozone and get a foot of each, they can size them.
fuel filter should be under small engine section, most vintage shops have them as they usually have rusted out tanks. bikemaster or anything generic should be good. on some bigger bikes, running a smaller one can restrict fuel flow but the ninja is a gas sipper so anything that fits the ID of your fuel line should be good. as long as it's just a filter, make sure you don't get one for EFI.
advance auto parts should have all this.
tc.young is offline   Reply With Quote
Old August 21st, 2013, 03:36 PM   #3
7oxSin
MSF Coach!
7oxSin's Avatar
awesome, i do all my shopping at Oriely's since i get 50% on most items. my petcock doesnt drip in off, just pours in on and reserve, so a rebuild would fix that problem.
Old August 21st, 2013, 03:43 PM   #4
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
Here try this first
http://www.ninjette.org/forums/showthread.php?t=141972
Runeknight95 is offline   Reply With Quote
Old August 21st, 2013, 04:13 PM   #5
MaxxVE
Motorcycle(s): 2006 Ninja 250
I'm having the same issue. I noticed my oil smelled a little like gas at the last change. I pulled the hose off the petcock and sure enough it's got a slow drip while on. I'm hoping I can repair it without spending any money on replacement parts.
MaxxVE is offline   Reply With Quote
Old August 21st, 2013, 04:22 PM   #6
Ask for a hose rated for gasoline and another for vacuum.
There is pneumatic valve (diaphragm and O-ring) that avoids fuel flowing down without vacuum.
Use these guides:
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
http://faq.ninja250.org/wiki/How_do_...fuel_filter%3F
Old August 21st, 2013, 06:45 PM   #7
7oxSin
MSF Coach!
7oxSin's Avatar
Use these guides:
you rock yoda!
ill rebuild the petcock here and let yall know how it goes.
Old August 22nd, 2013, 10:16 AM   #8
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Yah man, how much do you need?
AFM #676
Supersports are for n00bs
Old August 22nd, 2013, 11:24 AM   #9
7oxSin
MSF Coach!
7oxSin's Avatar
LOL
think ill be fine with a couple of them nice helmets.
hows that 300 treating you?
Old August 22nd, 2013, 01:55 PM   #10
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I have a spare HJC that has been dropped a few times, you can have it.
Her tires are melting
AFM #676
Old August 22nd, 2013, 04:24 PM   #11
n4mwd
n4mwd's Avatar
I've never seen a rebuild kit for the pregen, but I don't see why not. You can buy the essential parts at the dealer and rebuild it. You need to test your membrane. If the petcock itself leaks out the side or you can suck gas out of the vacuum line, then you need a new membrane. If not, then you might be able to get away with replacing just the o-ring on the membrane valve.
My Ninja Blog
Old August 22nd, 2013, 05:48 PM   #12
MaxxVE
Does anybody know if the newgen petcock fits the pregen bikes? It seems like replacements are much easier to find for the 08+
Old August 22nd, 2013, 09:03 PM   #13
n4mwd
n4mwd's Avatar
Its bolt compatible, but I don't know if it works beyond that. The gasket is slightly different on the newgen. The neck may be shorter on the newgen which would but the knob in a bad spot.
My Ninja Blog
Vacuum hose cross caused leak Quick1 1986 - 2007 Ninja 250R Tech Talk 9 December 23rd, 2013 03:19 PM
Possible gas leak from carbs or petcock issue agentbad 1986 - 2007 Ninja 250R Tech Talk 7 December 13th, 2013 07:45 AM
Minor Leak: Lower radiator hose Alkeplar 2013 - 2017 Ninja 300 Tech Talk 11 October 8th, 2013 07:09 PM
oil leak from an overflow hose? pinkandblack 2008 - 2012 Ninja 250R Tech Talk 30 June 17th, 2011 10:34 PM
Argh! Gas leak from petcock. Strange 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2009 03:07 PM
