Old July 9th, 2017, 08:21 PM   #1
BenjaNinja92
BenjaNinja92's Avatar
Motorcycle(s): 03 Ninja 250
Pregen Clutch/Brake levers
Anyone using aftermarket levers on their pregen? If so, what are some good ones that are easy to switch out?
BenjaNinja92 is offline   Reply With Quote
Old July 9th, 2017, 08:44 PM   #2
NaturalFlavored
Motorcycle(s): 250r
Look up the wiki page it'll tell you how to put on the adjustable levers I believe. Or look around on eBay or Amazon theirs mostly color choices If your not wanting adjustable ones. I bought blue levers and pegs.
Pegs have to be the correct size, I didn't know until after I bought mine so I had to rig it a little to work.
NaturalFlavored is offline   Reply With Quote
Old July 12th, 2017, 02:06 PM   #3
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
I just bought some generic adjustable levers on eBay for ~$25 from China. Keep in mind that even if the listing says they'll fit the 88-07 Ninja 250, they'll likely won't -- the clutch lever will fit, but the brake lever will not.
So once you receive them, you'll have to send the seller a message saying that the lever doesn't fit and send them some pics of the stock brake lever so they can get a better idea of the correct lever to send you.
At least that's what I had to do, but once I received the correct brake lever, everything fits and works great!
Cra1g is offline   Reply With Quote
Old July 26th, 2017, 03:49 PM   #4
Pigeonherd
Pigeonherd's Avatar
Motorcycle(s): 2006 Ninja250, 2014 Honda CB500X, '15CB300F
My dad just replaced the clutch lever on my '06 with one from a ninja500 from the same era. It's beefier, but also adjustable.
Pigeonherd is offline   Reply With Quote
Old July 26th, 2017, 05:43 PM   #5
Ghostt
Ghostt's Avatar
I just did the levers on my EX500, it's 1991 I ordered a set but the clutch didn't fit the perch, I hit my spare parts and found a perch from a newer model EX500, the one that is adjustable, and the new lever fit, so it was, a simple swap out the perch and it's all good now.
The earlier models of the EX500 87~93, which are referred to as 1st Gen share parts with the PreGen Ninjette, one of the being the levers in most cases.
violente et ignorantia
ZX-2R BLOG
Old July 26th, 2017, 05:57 PM   #6
Pigeonherd
Pigeonherd's Avatar
Is that reflective tape wrapped around your bar-ends?
Brilliant! (no pun intended)
Old July 26th, 2017, 06:20 PM   #7
Ghostt
Ghostt's Avatar
Yes it is black 3M reflective, I did that a long time ago, it does add some safety. Also I have reflective rim tape, and Ninja graphics on the tail section all in reflective orange.
The bar ends are extra heavy ones from HVMP.
ZX-2R BLOG
Brake and clutch levers ubnewbie Motorcycle Gear 13 July 21st, 2012 08:05 PM
