July 1st, 2009, 10:39 PM | #1 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
I need some measurements please.
Since I'm waiting on the new body and windscreen I feel like I'm neglecting the bike. I want to go ahead and mount my temp gauge but I need measurements first. Can someone measure behind the gauges from the line between the gauges and the plastic cover it mounts on to the windscreen. Then measure again 3 inches down in a straight line from the plastic to the windscreen. Stock windscreen or db it doesn't matter. I just need to know if I need to do some tweaking. Thanks.
Sportisimoto USA is born. |
July 1st, 2009, 11:41 PM | #2 |
The Sportisi Master
First person to get me measurements gets a free set of LED turnsignals.
July 2nd, 2009, 01:01 AM | #3 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Candy Plasma Blue Posts: 129
I'm not exactly sure what measurement your looking for, but I took a 2 1/16" gauge I had laying around and set it between the stock windshield and gauges. It would only sit flush with the gauges if I turned it upside down. The lightbulb entered the gauge I was using near the top, so if the light bulb is on the bottom half you should be good.
Last futzed with by Ken08Ninja; July 2nd, 2009 at 07:18 AM. |
July 2nd, 2009, 08:33 AM | #4 |
The Sportisi Master
I wasn't very clear in the first post. The plastic cover which the gauges mount to is where I need them from. The measurements needed all come from the v shaped area you see when standing infront of the bike looking down at the windscreen. I need a measurement from were the gauges meet the cover and then down about 3" but not to the point on a stock windscreen where the little dimples are. I have a similar sized gauge but pan on running a db windscreen so I know I will have a little extra room to play with.
July 2nd, 2009, 09:21 AM | #5 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
what kind of temp guage are you using?
Las Escobas -- Track Bikes Save Lives JonBroom.com |
July 2nd, 2009, 12:11 PM | #6 |
Matt - I'm not really sure what you needed from your description, so I took some pictures while I was at it....
July 2nd, 2009, 04:33 PM | #7 |
The Sportisi Master
Kim wins the prize pm me your address and I will mail them to you when they get in. Those were the measurements I needed just a little bit farther back The second picture is the first measurement I need the second one a few inches back. Broom I'm running a faze gauge ($20) for now I have a cyberdyne one in my garage somewhere which will be my permanent one
July 2nd, 2009, 07:18 PM | #8 |
do you still need me to get one a little further back? closer to the tip of the wind screen?
3 inches further back from the first ridge is about 1 3/4" to the screen... this is with the puig DB
July 2nd, 2009, 07:45 PM | #9 |
The Sportisi Master
nope thats all I needed. pm me your address.
July 4th, 2009, 08:48 AM | #10 |
420 President
Join Date: Jun 2009 Motorcycle(s): 09 Ninja grass color Posts: 96
damn i would have done this..
Rear Suspension measurements | WesleySnipes | 1986 - 2007 Ninja 250R Tech Talk | 6 | March 4th, 2013 05:53 PM |
I Need Measurements | AMMOCAN | General Motorcycling Discussion | 8 | March 4th, 2011 02:53 PM |
Tire temperature measurements | Domagoj | General Motorcycling Discussion | 3 | December 13th, 2010 09:24 AM |
[sportrider - sport bikes] - Weights and Measurements | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2009 01:29 PM |
[sportrider - tech] - Weights & Measurements | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2009 01:23 PM |
