June 17th, 2020, 07:57 AM | #1 |
Join Date: Feb 2020 Motorcycle(s): 2008 ninja 250r Posts: 21
Rear caliper won't go back together??
I just replaced the pads on my bike. no issues in the front. But the back calliper won't go back together. Not sure what its called but the sliding part only goes in so far then stops. and if i get it pushed in any it pops back out. any suggestions??
Thanks! |
June 17th, 2020, 09:35 AM | #2 |
The caliper just floats on the mount. When you put it back on, the disk will keep things in position. (unless I'm not understanding the problem)
June 17th, 2020, 09:47 AM | #3 |
Thanks for the reply! But wouldn’t that keep constant pressure on the disk from one pad?
June 17th, 2020, 10:08 AM | #4 |
Greased slider pins allow caliper to float laterally.
Be sure to use only high-temp silicone grease. Also replace accordion seals as necessary. Like this one. |
June 17th, 2020, 10:42 AM | #5 |
I think I'm following...
Sometimes when you disassemble, clean, and re-grease the sliding pins the grease seals the pin/bore and pressurizes the air inside and wants to keep the pin from moving completely into the bore. Too much grease will do that as well. You need to vent the pin/bore or remove some of the grease. |
June 17th, 2020, 05:12 PM | #6 |
Thank you!! Looks like to much grease was the problem and like you said it wasn’t able To compress completely
Thanks again! |
June 18th, 2020, 09:50 AM | #7 |
If it's squishy, that's actually air that's resisting. Just push caliper into pin really hard and it'll squeeze out excess air.
Double Checking: Front Brake Caliper Pistons Same Size as Rear Brake Caliper? | nocturncal | 2008 - 2012 Ninja 250R Tech Talk | 0 | March 15th, 2020 04:30 PM |
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air | MovingUp7 | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 28th, 2013 08:46 AM |
Need help getting rear brake caliper back on ASAP! | Falcor | 2008 - 2012 Ninja 250R Tech Talk | 27 | November 30th, 2012 09:37 PM |
Would a ex500 back brake caliper work on a ex250? | claymaker | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 6th, 2012 06:48 PM |
Rear brake caliper | Reswob | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2010 08:16 PM |
