Old August 24th, 2013, 03:55 PM   #1
agentbad
agentbad's Avatar
Possible gas leak from carbs or petcock issue
So I have noticed there is some gas on the bottom of my carbs and I can smell it sometimes when I am riding for a while. It's not gushing out or anything but when I run my hand on the bottom of the carb I can feel the gas and see it if I am looking right at it. I took a closer look today and took n4mwd's advice to pull the hose off the petcock when it's on the ON position sure enough it still leaks fuel. I've aslo notice a bit of gargle sound from the carbs when I start up especially when it's cold so maybe I have a messed up float too I am not sure. Where should I go from here? The bike only has 6400 miles on it but the previous owner didn't take care of the bike. It runs and idles well other then the gas issue.
Old August 24th, 2013, 06:14 PM   #2
Originally Posted by agentbad View Post
.........Where should I go from here?........
You could go reading Chadd's thread:
http://www.ninjette.org/forums/showthread.php?t=146834
Old August 26th, 2013, 05:16 AM   #3
agentbad
agentbad's Avatar
I'm not having any leakage from the overflow tube just on the carbs themselves. If the petcock is turned to the On position should gas still come out because it doesn't leak when it's off? I'm thinking about just buying another set of used carbs.
Old August 26th, 2013, 07:15 AM   #4
Carbs overflow when one or both float valves don't close properly.
They can leak through the bowls' gasket or the tube, the source is the same.
Petcocks that work properly are activated by the vacuum of the engine: engine off-no flow for any position.
You can service and repair your carbs, used carbs are not necessarily better than yours.
Here you can learn how to do it yourself:
http://faq.ninja250.org/wiki/Intake
Old August 26th, 2013, 07:54 AM   #5
CWLESQ
Motorcycle(s): '07 Ninja 250
I had a very similar problem. Assuming the float bowl drain screw is snug, the gas your finding on the bottom of the carb is evidence of a float/float needle issue. I would inspect the float needle valve within the carb and set your floats to spec (17mm), that should solve your problem.
CWLESQ is offline   Reply With Quote
Old August 26th, 2013, 10:36 AM   #6
agentbad
agentbad's Avatar
Okay I'll give that a try this week.
Old December 13th, 2013, 07:22 AM   #7
agentbad
agentbad's Avatar
Well it's the petcock that seems to be the source of the leak. I took the fuel hose off and it still dripped when it was on the ON position. If I put it on reserve it was a lot worse. If I shut off the petcock and leave the bike for while the carbs are clean when I come back. If I don't do this they collect gas on the bottom and around the idle adjustment knob. I also noticed a small gas puddle where I park the bike for a while. Another issue is when I took the vacuum hose off the metal nipple on the petcock came off with it. I tapped the thing back into place with the back of screwdriver and it seems to still be working alright but because of this I am considering just getting a brand new oem petcock instead doing a rebuild. Any thoughts?
Old December 13th, 2013, 07:45 AM   #8
Definitely fix the petcock, but it's not the real problem.
A vacuum petcock is just a back-up system. It's the job of the needle/seat/float to stop the flow of the gas in the carb - not the petcock.
If the needle and seat are closed securely you don't need a petcock that stops fuel flow unless there is vacuum (engine running).
Slow leak out of the top of the petcock hose 7oxSin 1986 - 2007 Ninja 250R Tech Talk 12 August 22nd, 2013 09:03 PM
Fuel Petcock Issue ans008 2008 - 2012 Ninja 250R Tech Talk 6 June 7th, 2013 07:14 PM
Gas not getting past the petcock ZeroG General Motorcycling Discussion 22 May 15th, 2013 02:54 PM
Strange fuel leak from carbs Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 7 April 23rd, 2013 06:24 AM
Argh! Gas leak from petcock. Strange 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2009 03:07 PM
