Old September 5th, 2010, 10:09 AM   #1
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
coolant mist!!
I have a bit of a strange issue. When I was top speed testing on a local rural road I ducked down behind the fairing and was greeted with a light mist of coolant to my face shield. I took the bike home and there was coolant all over the inside of the right side of the fairing around the cap. I took off the fairing and let her get good and hot idling and under part throttle and I could not reproduce the leak...absolutely dry! It was clear that coolant had been leaking in that area for some time but all the hose junctions and the cap were leak free
Is there a condition where the bike would only leak coolant at max speed? Or perhaps leaking very slowly and I only notice when the high wind blasts it onto my shield.
Thanks
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old September 5th, 2010, 10:33 AM   #2
mrlmd
mrlmd's Avatar
Did you notice if the temp gauge went way up when that happened?
Old September 5th, 2010, 11:21 AM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Did you check hose?
Do you know Allen Veracka or Bobby Bognano? Both are from Wareham. One is a biker, the other a chef.
Old September 5th, 2010, 11:38 AM   #4
Snake
Snake's Avatar
Check the cap to be sure it is on tight.
Old September 5th, 2010, 12:27 PM   #5
drstimpy
two wheels good
drstimpy's Avatar
Temp stays in normal range. Cap definitely tight although I am suspicious because I can't find leak anywhere else. All hose clamps are good and tight.
Old September 5th, 2010, 01:29 PM   #6
CC Cowboy
CC Cowboy's Avatar
Pin hole in hose that only sprays out when hot and super pressured?
Old September 5th, 2010, 01:58 PM   #7
change the radiator cap.
...or go for another top speed run (honestly officer, I'm troubleshooting my bike ), make the leak appear again, then immediately stop the bike on the side of the road and investigate the leak.
you can run w/o fairings to make it easier to identify the leak.
Old September 5th, 2010, 07:12 PM   #8
drstimpy
two wheels good
drstimpy's Avatar
will try a new cap...seems to be very easy to turn
thanks
Old September 5th, 2010, 10:14 PM   #9
I've been try to track down a similar condition. I took my fairings off and found the coolant level low (I can't ever see the level with them on). I added coolant and started trying to see where it was coming from. That's when I noticed dried coolant in the left fairing cut. There's a fixture right there but it was bone-dry at the end of that same ride. Coolant was still full a month later but the white remains of it had shown back up at the same spot several times that month, though sometimes it would remain clean even after a few hard and light rides (occurrence seems unrelated to engine load). Once, I was riding without my usual gloves (they were falling apart and I needed new ones) and felt a spray on my hands. I immediately pulled over and saw the tiniest of drops at that same fixture. There doesn't seem to be any looseness or cracking affecting the seal, so it probably just needs some kind of sealant around the fixture. That said, I don't see how I could have been sprayed by that and there weren't white spots everywhere else, so the spray is probably coincidental (external source). I just never felt it before because I always wear gloves.
Old September 6th, 2010, 07:33 PM   #10
drstimpy
two wheels good
drstimpy's Avatar
Went on a top speed run without fairing to look at cap area and absolutly no leaking. But when I was removing fairing I found some antifreeze puddled in the nooks and crannies. Maybe it was leftover from prior work on the bike and would only spray up when I went really fast (for a ninja 250). that's my theory for now. will update if problem resurfaces.
thanks all
Old September 6th, 2010, 07:35 PM   #11
if you still have the fairings off, wash it clean under there so you can tell if more leaks occur in the future.
good to hear the problem has abated for now. keep a close eye on your temp gauge.
Old September 7th, 2010, 03:19 AM   #12
drstimpy
two wheels good
drstimpy's Avatar
cleaned them up before re installing. Can a little cooant come out under extreme conditions? about a month ago I was in stop and go traffic for more than an hour. The temp gauge never went out of the normal range but the fan ran a lot. certainly didn't detect any antifreeze smell at that time but the amount in the fairing was small...a tablespoon of two.
Old September 7th, 2010, 03:40 AM   #13
any coolant that boils over past the cap is supposed to be routed to the reservoir, so in reality, you shouldn't be seeing any coolant overflowing at all in that area. What coolant does overflow the reservoir is supposed to be routed through a hose that exits right in front of the rear tire area.
http://faq.ninja250.org/wiki/How_do_...ling_system%3F
fan running in stop and go traffic is normal and if your temp gauge is functioning correctly, the system sounds like it's operating as designed.
how are the coolant levels in the radiator and reservoir?
Old September 8th, 2010, 03:41 AM   #14
drstimpy
two wheels good
drstimpy's Avatar
reservoir was about where I left it so if some coolant escaped, it wasn't a huge amount.
When a little coolant gets into the bodywork, it sits there forever. So I cant tell when it got there.
Old September 28th, 2010, 04:33 PM   #15
drstimpy
two wheels good
drstimpy's Avatar
just got back from 1600 mile trip on the bike and didn't have any problems until I blew a downshift and banged off the limiter. Then got some coolant leaking through cap...need new cap I think.
Old September 28th, 2010, 04:39 PM   #16
yeah... replace it. OEM is about $20, maybe cheaper if you can find something at the auto parts store that matches.
Old November 2nd, 2010, 03:29 AM   #17
drstimpy
two wheels good
drstimpy's Avatar
Replaced cap and it still does it. Doing hoses next. Will update when done. Btw did 1500 mile trip through Maine vt nh and NY and it was the perfect travel companion!
[motorcyclenews.com - sport] - Indianapolis Moto2: Red mist descends as Redding takes Ninjette Newsbot Motorcycling News 0 August 18th, 2013 12:30 AM
[motorcyclenews.com - sport] - Indianapolis Moto2: Red mist descends as Redding takes Ninjette Newsbot Motorcycling News 0 August 17th, 2013 02:10 PM
[roadracingworld.com] - MIST Suzuki Will Compete In British Superbike Finale At Oulto Ninjette Newsbot Motorcycling News 0 September 28th, 2010 09:40 AM
[twistingasphalt.com] - A Clearing in The Mist Ninjette Newsbot Motorcycling News 0 December 10th, 2009 06:41 PM
[crash.net - WSBK] - MIST descends on BSB Ninjette Newsbot Motorcycling News 0 March 11th, 2009 09:40 AM
