Old October 31st, 2010, 11:05 AM   #1
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
Question intermittent turn signal
I have a 2004 with everything about perfect except the turn signals will very occaisionally not work at all. from time to time they just take 10 minutes off and then everything is fine. Any quick thoughts on how to most efficiently troubleshoot this issue?
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old October 31st, 2010, 11:08 AM   #2
drstimpy
two wheels good
drstimpy's Avatar
Oh yeah
all 4 bulbs are fine. When I flip the switch, sometimes nothing happens. Once in a while the blinkers run a wee bit slow too.
thanks
Old October 31st, 2010, 12:17 PM   #3
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Maybe a bad turn signal relay
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old November 1st, 2010, 08:12 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Clean the corrosion out of the bulb sockets and apply some silicone grease on the bulb bases before reinstalling. Pull the turn signal relay and do the same there, as well as the connectors at the turn signal stalks. If the problem persists likely it's corrosion in the switch itself. It's not hard to work on. The switches are not waterproof.
Old November 1st, 2010, 10:41 AM   #5
drstimpy
two wheels good
drstimpy's Avatar
I have serched the forum and wiki...hate to admit I don't know where the relay is
I have done pretty much everything to my bike and never done any electrical stuff.
Thanks for the help
Old November 1st, 2010, 05:45 PM   #6
FrugalNinja250
It's under the right side cover, a black box about 1.5 x 1.5 x .75 inches, mounted so the wires come out the bottom and a plastic tab with one screw at the top. it's only got two wires connected to it.
Old November 1st, 2010, 07:39 PM   #7
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
+1...or a bad switch. Check the relay first, though.
Old November 2nd, 2010, 03:26 AM   #8
drstimpy
two wheels good
drstimpy's Avatar
Just examine it for corrosion and dielectric grease all connections? Or should I just replace it?
Thanks again
Old November 2nd, 2010, 06:03 AM   #9
coolbreeze
coolbreeze's Avatar
Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA
Check the undertail wires. I had the same problem. When my bike was bottoming out, the tires were rubbing against the wires. Eventually, it just about cut through the wire and my blinkers wouldn't work all of the time. I repaired the wires and tucked them in more. No problems now.
coolbreeze is offline   Reply With Quote
Old November 2nd, 2010, 06:22 AM   #10
FrugalNinja250
Thanks again
They're a bit pricey, aftermarkets run around $20. I'd focus on the cheap fixes first like cleaning and greasing the terminals. You'll probably want to clean and grease the turn signal switch before buying a new relay. BTW, I've taken a relay apart and it's actually a solid-state flasher module inside the potting compound. I'd think that of all the things that could go wrong in the turn signal circuit (which is very simple, BTW) the relay would be at the very bottom of the list of probabilities.
Old November 5th, 2010, 04:37 AM   #11
drstimpy
two wheels good
drstimpy's Avatar
WOW
I cleaned and dielectric greased all the terminals on the bike and gooped up the inside of the turn signal switch. Now the signals flash twice as fast but have been working without interruption
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
having an intermittent starting problem! davidfriend 1986 - 2007 Ninja 250R Tech Talk 8 April 18th, 2012 05:16 AM
Intermittent Horn Problems Dimsum_The 1986 - 2007 Ninja 250R Tech Talk 2 April 15th, 2012 06:07 PM
Intermittent Clunk 2005 gogiburn 1986 - 2007 Ninja 250R Tech Talk 1 August 18th, 2010 07:31 PM
Intermittent headlight dowmace 1986 - 2007 Ninja 250R Tech Talk 3 May 19th, 2010 09:55 AM
