Old June 23rd, 2013, 11:41 AM   #1
cmcintyre13
Unhappy 2012 250 not getting gas? please help!
okay so i started up my 250 on friday to go to work, and it seemed really muffled. i took my car and today i checked again. took it for a ride and it seems like it isn't getting gas.. i have no idea what's going on. could this be a product of getting bad gas?
cmcintyre13 is offline   Reply With Quote
Old June 23rd, 2013, 12:32 PM   #2
DaBlue1
DaBlue1's Avatar
Why would you suspect bad gas?
Had the bike been sitting for a while or you recently purchase some suspect gas?
Did you try opening the gas cap to see if it needed to vent?
Have you checked to see if something possibly fell down under the passenger seat and is blocking the snorkel?
Have you checked the air filter and airbox?
Did you use the choke and warm up the bike enough prior to pulling off?
Old June 23rd, 2013, 12:36 PM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
nice introduction welcome
Why do you think it's not getting gas
we need more details of the symptoms in order to help.
Old June 23rd, 2013, 02:06 PM   #4
cmcintyre13
it had only sat over night, the night before i put gas in, but i usually go there for gas.
how do i get to the airbox? and where would i check to see if something fell through. the only thing i keep in the passenger seat is the alarm and it's there. i also did use choke
as far as symptoms its just as before.. the rev just sounds really muffled. and it's extremely weak. i tried to ride around the block to see if i could think of anything and it just seems its not getting anything..
Old June 23rd, 2013, 02:16 PM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
To get to the air box and filter you need to remove the plastic side cover I have three fingers on, its just the one silver bolt then pull and it will release from the rubber grommets. After that you need to pull of the air box cover and that's held on with the three black bolts, my index finger is pointing to one of them. After removing the cover you should see the snorkel and then from the passenger seat area look down through it.
Old June 23rd, 2013, 02:17 PM   #6
What and when was the last work on the bike done (repair, service or upgrade)?
Welcome to our site, Chris !!!
Old June 23rd, 2013, 02:21 PM   #7
cmcintyre13
what would i need to be looking for in the airbox?
last time work was done to the bike was an oil change i did at 3000 miles (currently has 4500ish) i did not overfill oil or anything. before that i had a slip on put on at around 1000 miles. and then the 600 mile service
Old June 23rd, 2013, 02:34 PM   #8
..........last time work was done to the bike was an oil change i did at 3000 miles (currently has 4500ish) i did not overfill oil or anything. before that i had a slip on put on at around 1000 miles. and then the 600 mile service
Then, it could be something in the fuel.
Water is the most common substance that causes problems, because is heavier than fuel (goes to the bottom) and cannot be sucked from the carburetor.
Draining the bowls is simple and effective, unless more water is in the bottom of the tank.
Some times, it also happens after the bike has been exposed to heavy rain.
There are cases in which something (like a rag) falls into the airbox and blocks the air intake.
Last futzed with by Motofool; June 23rd, 2013 at 06:35 PM.
Old June 23rd, 2013, 02:36 PM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
A video is always quite helpful
Old June 23rd, 2013, 02:41 PM   #10
cmcintyre13
it was exposed to some heavy rain a few times when i wasn't able to cover. no garage due to living in an apartment. a video would be very helpful.
Old June 23rd, 2013, 02:54 PM   #11
cmcintyre13
another problem i've been having recently is that when i shift up or down sometimes my shifter won't spring back down into place. if that makes any sense
Old June 25th, 2013, 11:31 AM   #12
cmcintyre13
just an update. i checked to see if anything was in the snorkel and there wasn't anything.
i also put heet in the tank to get rid of any water. still no dice.
any ideas?
Old June 25th, 2013, 11:35 AM   #13
........any ideas?
New or old ones?
http://www.ninjette.org/forums/showp...21&postcount=8
Old June 25th, 2013, 11:42 AM   #14
cmcintyre13
info on how to drain the bowls?
nothing is in my intake i checked that.
Old June 25th, 2013, 12:17 PM   #15
DaBlue1
DaBlue1's Avatar
Are you briefly letting the tension off the shift lever so that it may spring back.
You may also want to check to make sure the shift lever is properly adjusted and tightened.
....i also put heet in the tank to get rid of any water. still no dice.
any ideas?
How much did you use. It may be easier for you to drain the gas tank and refill with fresh fuel if you think there is that much water in the tank. Drain some in a clear jar and wait several minutes to see if water settles to the bottom of the jar. More than a few people have gassed up the night before then the next day have running problems out of nowhere, due to bad gas.
Old June 25th, 2013, 12:27 PM   #16
cmcintyre13
and how do i go about draining the tank?
Old June 25th, 2013, 12:49 PM   #17
DaBlue1
DaBlue1's Avatar
Get about a foot of 1/4 fuel line from any auto parts store.
Get a gas can, bucket or container big enough to collect the old gas.
Locate the petcock, then find the larger diameter hose that attaches to the side of the carb.
Make sure the petcock is in the on position, then pinch the hose clamp and remove the hose from the petcock. It may be a little hard coming off, but work easy with it.
Attach the foot long fuel line to the petcock, place one end into the container and turn the petcock on PRI to drain the tank.
Old June 25th, 2013, 09:48 PM   #18
cmcintyre13
okay so an update. i got a siphon and took all the gas out of the tank. tomorrow morning ill turn it on until it dies to make sure it's all out. along with that is there anything else that i should check for that could cause this to be happening??? thank you so much for the help btw.
Old June 26th, 2013, 04:50 AM   #19
DaBlue1
DaBlue1's Avatar
.... along with that is there anything else that i should check for that could cause this to be happening???
An air filter that is wet or overly saturated with oil can restrict airflow as well as an extremely dirty one.
Old June 26th, 2013, 09:21 AM   #20
cmcintyre13
and getting to the air filter means that ill have to pull just about everything off the bike correct?
Old June 26th, 2013, 09:26 AM   #21
DaBlue1
DaBlue1's Avatar
No. Just the large black side panel and the airbox cover underneath.
See pic in post #5
Old June 26th, 2013, 09:36 AM   #22
cmcintyre13
oh okay, just the filter that pulls out? how should i go about cleaning it?
Old June 26th, 2013, 09:46 AM   #23
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I think its the same as any Dirtbike foam filter so its kind of a pain in the ass. I swapped mine to the K&N replacment(not pods) so it would be easier to clean in the future.
Old June 26th, 2013, 10:02 AM   #24
cmcintyre13
okay i googled it and it says to wash with dish soap until water comes out clear and then soak it with oil before putting it back in. sound correct?
Old June 26th, 2013, 10:07 AM   #25
DaBlue1
DaBlue1's Avatar
If it's extremely dirty, remove the black frame (they simply snap together.).You may use a foam air filter cleaner or a little carb cleaner to clean with. if dirty is caked on it, use something the lightly brush off the layer of dirt. Make sure the filter is completely dry after cleaning and then very lightly re-oil the filter with engine or air filter oil. Add a tiny bit of oil inside a zip- lock bag and get the filter totally coated with the oil.
If the filter is a little less dirty, you can use some warm water and a degreaser or dawn dish soap. Rinse, dry completely, then re-oil.
Also look at the steel mesh screen inside the airbox the make sure the holes are not clogged by dirt, corrosion or rust. Clean any dirt or debris inside the airbox as well.
Old June 26th, 2013, 10:10 AM   #26
indr
A new filter element doesn't cost much to replace every year, so do that if it's too dirty. Unless you're a cheap bastard like me.
indr is offline   Reply With Quote
Old June 26th, 2013, 10:22 AM   #27
cmcintyre13
how do i get to the airbox, i pulled out the filter and it doesn't seem extremely dirty so i'm gonna go ahead and wash it.
Old June 26th, 2013, 10:44 AM   #28
indr
You want to remove the airbox? You'll need to remove the rear wheel, passenger pegs, rear fender, and battery box. It's best to shine a flashlight down the hole where you removed the air filter from and see if there is any debris in there. Also shine one down the snorkel (on the right side of the airbox; towards your left if looking at the airbox from the airfilter slot side).
Also, make sure your filter is totally dry of water before oiling it again.
Old June 26th, 2013, 11:32 AM   #29
cmcintyre13
okay right now i'm letting the filter dry before i re oil it. i wasn't able to get the frame off, it's obviously smarter than i am. lol
edit: after messing a little more i was able to get the frame off will update later!
Old June 26th, 2013, 12:57 PM   #30
indr
I was afraid that I'd break the frame and didn't bother removing it for the first few times when I cleaned the filter. You just have to slide your fingers down between the two columns, one at a time, and just yank. They won't break. Just make sure you pull evenly.
EDIT: You got them off, NVM.
Old June 26th, 2013, 03:51 PM   #31
cmcintyre13
okay so i dried the filter and reoiled it. i put it back in and went to start the bike and.... it seems i have a completely new problem... ignition button is doing nothing... so now my bike won't even start...
Old June 26th, 2013, 04:04 PM   #32
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Maybe your battery is dead now
Old June 26th, 2013, 04:24 PM   #33
cmcintyre13
im guessing im not able to charge it up with regular jumper cables? dunno why it would be dead.
Old June 26th, 2013, 04:32 PM   #34
DaBlue1
DaBlue1's Avatar
Dash lights on?
Emergency shut off switch in the run position?
Bike in neutral?
Have you tried kickstand up, clutch in to start?
What's the voltage on the battery?
Old June 26th, 2013, 04:37 PM   #35
cmcintyre13
it's daylight so i didn't see the dash lights, but gas guage was working so i guess that means battery is okay.
turn off is in the on position.
ill check if it was in neutral, also the kickstand here soon.
battery is stock for 2012 250 so i haven't seen it.
will check all of those soon.
Old June 26th, 2013, 04:50 PM   #36
DaBlue1
DaBlue1's Avatar
When you turn the key on you should see the oil pressure light (red) and the neutral light (green if the bike is in neutral).
A working gas gauge does not necessarily mean that the battery is good. Even a weak battery can operate the lights, but not turn over the motor, however it will give an audible clicking noise.
Old June 26th, 2013, 05:18 PM   #37
cmcintyre13
okay so i went back out there and still the same problem. but i was able to get it started this time. ideas? uploading a video of how it sounds soon.
edit: http://youtu.be/BpFlo9oJuTA
Old June 26th, 2013, 06:18 PM   #38
DaBlue1
DaBlue1's Avatar
Video is private.
Old June 26th, 2013, 06:24 PM   #39
cmcintyre13
sorry try again
Old June 26th, 2013, 07:48 PM   #40
DaBlue1
DaBlue1's Avatar
Sounds like your idle rpms are too low. Locate the idle adjustment knob, turn it to the right about a 1/4 turn, start the bike using the choke. With the choke on, the rpms should be around 2-3k. Once the bike is fully warmed you will have to adjust the idle with the choke off to 1350 +/- 50 rpms.
