Old June 29th, 2018, 07:04 PM   #1
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
Something Melting / Dripping onto Exhaust
Hey guys,
I've owned my Ninja for 8 years now and been around these forums for about that long as well, and have never heard of this one. So I took a 20 mile "spirited" ride around the lake, and when I parked I noticed smoke coming up from my exhaust in the area of the gear selector. Sure enough, something was dripping onto it.
It's definitely not coolant (been there done that), and does not look nor smell like oil. It almost looks like a ton of melted road tar, it's a goopy consistency. The only other thing I can think of is maybe it's an overflow hose melting, or even the sheath to a wiring harness melting? I really have no clue. I find it odd that this has never happened before though.
It was getting dark when I got back from the ride, so I figured I'd throw this out there to see if anyone has had/heard of anything similar to this. Either tomorrow or the next day, I'll put it on the center-stand in daylight and look into it further. I attached some pictures of what I'm dealing with.
1994Ninja250F is offline   Reply With Quote
Old June 29th, 2018, 08:54 PM   #2
What's it taste like????
Old June 29th, 2018, 09:15 PM   #3
Ram Jet
Ram Jet's Avatar
Originally Posted by 1994Ninja250F View Post
Hey guys,
Eight year build-up of chain lube?
Bill
Old June 30th, 2018, 07:39 AM   #4
1994Ninja250F
‘94 Rider
Bill
Was thinking that, since it does have kind of a grease smell to it. And the underside of my bike could use a good degreasing. Do you usually get a buildup of lube there? I thought the front sprocket was fully contained and shielded within that front sprocket cover and thus, shielded from this kind of situation. Apologies if I’m wrong on that, drove my car to work today/don’t have bike in front of me to look at right now.
Old June 30th, 2018, 08:44 AM   #5
Ram Jet
Ram Jet's Avatar
There can, and probably is, a grrrrrrate deal of crud under the sprocket cover. Open er' up and see what I mean. Especially if you have been diligent in lubricating your chain. The counter shaft (small) sprocket is exposed just like the rear sprocket.
Bill
Old June 30th, 2018, 10:05 AM   #6
It's shielded in sense that oil can't get flung outwards to coat your calf and engine. But it's still being flung away from chain and gets caught on inside of sprocket guard. Over time it builds up to many, many gallons stuck to inside surface. Eventually it builds up enough to actually touch chain and gets scraped down and out by moving chain.
Remove sprocket guard and clean out insides.
Old June 30th, 2018, 10:52 AM   #7
1994Ninja250F
‘94 Rider
I opened it up and that looks to be the exact issue, and yes I lube the chain every 2 tanks of fuel so about every ~500 Miles. Thanks to all for the help!
Old June 30th, 2018, 01:23 PM   #8
Ram Jet
Ram Jet's Avatar
See, that's what you get for proper maintenance! Good for you Sir!
Bill
Old June 30th, 2018, 02:30 PM   #9
1994Ninja250F
‘94 Rider
Bill
Haha right? Now it gives me an excuse to strip the bike down and get all the gunk and goo out of all the nooks and crannies. I’m honestly surprised it took 8 years for this to happen, that’s a lot of chain lube!
Old June 30th, 2018, 02:44 PM   #10
Ram Jet
Ram Jet's Avatar
Your OK! You'll be riding that little baby till 2030! I'm riding my 07' to the Keuka Park Cemetery. Unless I find a 1971 Ducati 750 Super Sport in the interm.
Bill
[motorcycle.com] - 26,182 Victory Touring Models Recalled for Melting Brake Lines Ninjette Newsbot Motorcycling News 0 November 3rd, 2017 10:21 AM
[motorcycle.com] - Observations From The Road: Melting Down Ninjette Newsbot Motorcycling News 0 April 16th, 2014 10:10 PM
dripping coolant tazman 2008 - 2012 Ninja 250R Tech Talk 7 May 14th, 2011 04:11 PM
[topix.net] - Malaysian melting pot awaits Rizla Suzuk Ninjette Newsbot Motorcycling News 0 October 20th, 2009 03:00 PM
[roadracingworld.com] - See What Happened To Mladin And Hacking Under The Dripping Br Ninjette Newsbot Motorcycling News 0 August 6th, 2008 10:46 AM
