Old June 17th, 2012, 12:17 PM   #1
psych0hans
psych0hans's Avatar
Buying dirt cheap camera for ninjette...
Found this cam on ebay and picking it up... Tiny lil thing, so shouldn't be hard to mount pretty much anywhere and comes with two mounting options...
GearXs Mini DV MD80 DVR Video Camera
GearXs Mini DV MD80 DVR Video Camera w/8GB Memory -The World's Smallest Video Camera!
Condition: New (more info)
Packaging: as Bulk
Model: MD80-8GB
Weight: 0.25 lbs
Product Description:
The Mini DV MD80 is the smallest digital video camera in the world! Smaller than a BIC lighter, and just about as cheap! It is very fashionable and wearable and matches all kinds of portable tools, making it a good little cam unit. It records 720X480 video in AVI format at 30 frames per second this AEE camcorder keeps away blur and distortions. It can be set to stand-by for up to 250 hours until it is activated by a sound.
You can set it up in a room on audio-activated standby mode, where it will happily sit for nearly two weeks on a single battery charge, waiting for a noise to start it recording. It uses microSD, which means you can store up to 16GB of footage on it, and it plugs into your computer via USB (which also charges it) to let you transfer files.
With a 2000000 color CMOS sensor, the AEE MD80 video camera captures videos with impeccable clarity and acute details. This video camera, with 80 degree view angle, lets you capture landscape videos on a wider angle. With an extensive memory support, this AEE camcorder offers ample of storage space. The thumb size manual alloy housing of this video camera offers reliability and longevity. Powered by the Li-battery, the AEE MD80 lasts for up to two hours. Comes with 8GB MICRO SD Card.
Features:
Thumb size alloy housing
Manual and sound activated recording
Web camera for online video chat
Supports AVI video format
Low illumination, high resolution image with 2000K pixels
High speed recording and quick light response
30 frames per second for 720*480 video output
Built-in Li rechargeable battery lasts 2 hours
Supports 16G memory card (max)
Easy operation with LED indicator
Supports USB 2.0
Flexible installation with clip and bracket
Supports JPEG picture format
8GB Micro SD Card included
Specifications:
Pixel
2000000 color CMOS
View Angle
50°
Minimum Illumination
1Lux(Min)
Battery Capacity
230mAH
Consumption Current
120mA/3.7V(Max)
Store Temperature
-20℃ ~80℃
Operation Temperature
-10℃ ~50℃
Operation Humidity
15-85%RH
Memory medium
Micro SD Card (TF Card)
SD Capability
Max 16GB Micro SD Card
Video Function and Format
Video decode use motion JPEG,recording for AVI format.VGA (720*480@30frame/second)
USB Jack
USB 2.0
Weight
19g(approx.)
Dimension
55x20x20mm (approx.)
Operation System
Windows 98SE/2000/Me/XP/Vista, Mac OS10.4
Old June 17th, 2012, 12:27 PM   #2
mustang5.0
Motorcycle(s): 2011 GIXXER 600
im buying one... needed a spy cam
"You see it's not the blood you spill that gets you what you want. It's the blood you share, your family, your friendships, your community. These are the most valuable things a man could have."
mustang5.0 is offline   Reply With Quote
Old June 17th, 2012, 12:32 PM   #3
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
i thought about getting one of those but dont know if its good enough...
would be cool if you could post a vid of the video quality when you got it...
PsHYk is offline   Reply With Quote
Old June 17th, 2012, 12:33 PM   #4
toua70
toua70's Avatar
Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission)
Actually have it on watch right now BC not sure of quality. Let us know!
toua70 is offline   Reply With Quote
Old June 17th, 2012, 12:35 PM   #5
bkh2
bkh2's Avatar
Motorcycle(s): 2006 GSXR 750; 1983 CB750SC
I have that exact one. The picture quality is quite lacking but I suppose it depends on what you want out of it. For me, it was fine because I'm not uploading it to Youtube or anything. Lower your expectations (a lot) if you don't want to be disappointed.
bkh2 is offline   Reply With Quote
Old June 17th, 2012, 12:36 PM   #6
mustang5.0
its cheap.. it will be cheap.. if i had loot, i would get a go pro, but im broke
Old June 17th, 2012, 12:47 PM   #7
bkh2
bkh2's Avatar
You're right. It's good for what it is, but all I'm saying is just don't expect near-GoPro quality because you will be severely disappointed.
Old June 17th, 2012, 12:53 PM   #8
It sure looks like the same camera that a few people picked up in this thread. Can I merge them?
Old June 17th, 2012, 12:57 PM   #9
mustang5.0
looks the same to me
Old June 17th, 2012, 01:03 PM   #10
akima
Nooblet
akima's Avatar
MOTM - Oct '13
The camera case looks visually the same, by the electronics inside could be completely different. The branding on the case is different between the two.
Old June 25th, 2012, 12:41 AM   #11
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Old June 25th, 2012, 01:03 AM   #12
psych0hans
psych0hans's Avatar
Originally Posted by nickjpass View Post
I've already placed an order for it, will post a video as soon as I get it. From this video, it seems passable, especially at this price.
Old June 25th, 2012, 01:06 AM   #13
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
If I rode the street, I'd get one and use it in case I was in an accident or something.
Old June 25th, 2012, 10:03 AM   #14
toua70
toua70's Avatar
pulled the trigger on this one.. just bought one. HOpefully it'll arrive this week
Old June 25th, 2012, 11:50 AM   #15
I'm Fred
I'm Fred's Avatar
Motorcycle(s): None yet :(
The quality in that video looks pretty amazing for the price. Could be very useful incase you get in an accident
I'm Fred is offline   Reply With Quote
Old June 25th, 2012, 11:56 AM   #16
PsHYk
PsHYk's Avatar
yeah i was thinking its good enough quality to be a witness...
Old June 25th, 2012, 01:32 PM   #17
Maielstrom
Ghost Rider
Maielstrom's Avatar
Would definitely love to hear people's experiences with these cameras! I just received a handlebar camera mount (http://www.ebay.com/itm/200738305429...4.m1497.l26490) but haven't been able to test it out yet do to crazy weather today. It was a little too wide, so I had to trim the sides a little, as well as move my clutch lever a few centimeters to get it to fit on the handlebar. I'll be able to get my little handycam on there no problem (A/V nut, so HD is ideal), but I think the view will be half through the windshield/half over the windshield.
If the reviews on this camera are decent, I may look into that until I have the cash to pick up a GoPro
Maielstrom is offline   Reply With Quote
Old June 25th, 2012, 03:12 PM   #18
diablos991
diablos991's Avatar
Motorcycle(s): 2009 Ninja 250 (blue)
I own one of these cameras.
But I haven't got around to getting a MicroSD installed in it and attaching it to my helmet.
diablos991 is offline   Reply With Quote
Old June 25th, 2012, 03:20 PM   #19
toua70
toua70's Avatar
yeah i checked out youtube and quality seems to be impressive. I got mine for 19.99 with the 8gb card included. If i get it this week, i'll post up a video link if no one else does it by the time i get mine. Just to show the quality of it. SOme guy off youtube runs 2 of these cameras. One in the helmet and one on the frame sliders with velcro. My friend actually told me about this camera awhile back i just forgot about it. He used to have one until he got a gopro for christmas. He said they're really good.
Old June 25th, 2012, 06:41 PM   #20
blackoutt
blackoutt's Avatar
Motorcycle(s): 08 R6, 08 250R
That video up there has a 2008 recording date on it? Is the technology just so cheap because it's so old? It can't be very good quality.
YEAH BUDDY!
blackoutt is offline   Reply With Quote
Old June 26th, 2012, 02:27 AM   #21
newninja123
newninja123's Avatar
Motorcycle(s): 2012 black Ninjette
there are better ones on the internet, worth having a look around a bit more..
Ride safe, be safe..!
newninja123 is offline   Reply With Quote
Old June 29th, 2012, 05:09 PM   #22
toua70
toua70's Avatar
just made a quick video
sorry for the angle. First time i ever used this thing. Not too bad my opinion
Old June 29th, 2012, 05:27 PM   #23
xSean13
xSean13's Avatar
Picture quality is okay, fps seems pretty low & choppy. For dirt cheap, good deal though.
Old June 29th, 2012, 05:32 PM   #24
toua70
toua70's Avatar
its not too bad i just have to mess around to get the right camera angle. I shall go invest in some velcro!
Old June 30th, 2012, 06:31 AM   #25
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
For $20 I think it's pretty good
NJ Ninjette is offline   Reply With Quote
Old July 1st, 2012, 06:43 AM   #26
psych0hans
psych0hans's Avatar
thanks for taking the effort to do this review.
Old July 10th, 2012, 04:43 PM   #27
Maielstrom
Ghost Rider
Maielstrom's Avatar
Thanks for the test video! Definitely persuaded me to pick one of these up as the handlebar mount I bought is only good for videoing the rider through the mirror. Just wanted to ask how were you able to mount it inside your helmet and get that kind of visibility?
Old July 10th, 2012, 04:54 PM   #28
toua70
toua70's Avatar
i used velcro tape. I just taped it to the side of my helmet. If you youtube it, you should find a video of how others did it. It won't be in the way. I actually bought the new drift HD camera because I lost this one i was sad about it because its actually a good camera for 20 bucks. So I just ended up buying the drift.
Old July 10th, 2012, 05:16 PM   #29
Maielstrom
Ghost Rider
Maielstrom's Avatar
Ahh cool stuff, I'll def look into that! I bought one from a different company cuz the camera only cost 9 and change (bought a separate 8 gig card for 4 bucks), which claims it comes with a magnetic swivel base, so I may see how well it can sit on the gas tank. Inside the helmet would be ideal though, as I would like to be able to have voice recording on the same file, rather than have the audio and video separate then combine them post production. Sorry to hear that you lost your cam, though the video from the drift must be excellent! My intention is to use the cheap camera just for now as the summer (for me) is nearing an end, so I won't be able to buy and use a higher end camera until next summer unless we get another warm winter here haha
Old July 10th, 2012, 06:55 PM   #30
toua70
toua70's Avatar
The magnetic mount thing is horrible. Its super weak and will not hang on the gas tank or anything :/
Old July 10th, 2012, 07:07 PM   #31
Maielstrom
Ghost Rider
Maielstrom's Avatar
Haha thank you! Gotta actually see what it looks like and all that, but I'm thinking possibly some velcro under the windshield if the helmet thing doesn't go too well. I may pair it with video from the handlebar mount, so I'd have to do post production anyway where the audio wouldn't be much an issue
Old July 10th, 2012, 07:30 PM   #32
C L
Motorcycle(s): 2014 300
Got mine in the mail today..
Camera doesn't seem to record for more than about 30 minutes after 6 hours of charging
Did you have any problems like this?
C L is offline   Reply With Quote
Old July 10th, 2012, 07:58 PM   #33
toua70
toua70's Avatar
yeah, that 2 hours recording time claim is a bunch of BS. I took it up to a canyon with me and it died before we got to the first stop. I lost it because i mounted it on my plates with double sided tape... vibration caused it to come off.. lost it on the fwy
Old July 11th, 2012, 06:22 AM   #34
Graugaard
Graugaard's Avatar
Personally i dont like it. a gopro 960 is only what? below 100$ used probably. Its so much more enjoying watching HD on your TV from your rides with your friends imo . memories are best when in high quality, but if this is your only option, cus of low money then i understand, but if not it is worth offering the extra money on a real action camera.
Graugaard is offline   Reply With Quote
Dirt cheap hydration packs on eBay... psych0hans Gear-related 13 September 3rd, 2012 12:40 PM
[M13] If a dealer talks a new rider out of buying a ninjette... akima Videos 59 June 25th, 2012 05:34 AM
potential camera for ninjette? psych0hans General Motorcycling Discussion 16 June 11th, 2012 05:36 AM
[motorcyclistonline] - Dirt Cheap | Cat Tales Ninjette Newsbot Motorcycling News 0 March 30th, 2012 09:30 PM
buying a dirt bike Domagoj General Motorcycling Discussion 7 October 15th, 2010 03:59 AM
