Old May 29th, 2012, 09:02 AM   #1
Chuffmonkey
Chuffmonkey's Avatar
Motorcycle(s): 2012 Triumph Street Triple R, 2011 250R SE (sold 5/8/13)
Leaking coolant
For a few weeks now there has been white water residue on the right side fairings, which I assumed were just from riding through water somewhere. Well, this weekend I took a quick ride around the block after tightening the chain and, when I parked back on my drive, I noticed the bike was dripping coolant.
As I start to look, the right side of the engine is covered in dried coolant - which is also what the water marks are on the outside of the fairings. There is a small pool in the bottom of the fairings.
The level in the expansion tank is slightly low (maybe 1/4" - 1/2" from full) - I sprayed down the engine to clear it all off and took another ride around the block. Nothing new appears to be leaking after the 2nd ride but of course I'm now concerned.
Any ideas?
Chuffmonkey is offline   Reply With Quote
Old May 29th, 2012, 09:49 AM   #2
cuong-nutz
cuong-nutz's Avatar
Perhaps the cap on the reservoir was not tight or you could have a leaky hose.
HalfFast Racing Team
Old May 29th, 2012, 10:21 AM   #3
DaBlue1
DaBlue1's Avatar
Over time hose will shrink a tiny bit due to heat and become a little loose. The best thing to do is tighten down all the clamps, clean off the areas that are stained and watch for any more leaks, especially under really hot temps. Elevated temps equal longer periods of pressure and heat. If tightening the clamps do not help, replace the hose, recheck and top off the coolant levels as necessary.
Old May 30th, 2012, 09:34 AM   #4
Chuffmonkey
The cap definitely wasn't loose as it took a lot of effort to take it off. It could be shrunk hoses. Another question though: the bike is less than a year old. Could this be covered under the warranty?
Old May 30th, 2012, 01:28 PM   #5
if its under warranty i would think that should be covered
Old May 30th, 2012, 11:47 PM   #6
Trainsk8
Motorcycle(s): 2010 Kawasaki Ninja 250R
This same thing happened to me! I was quite worried until i found that the cheap "clamp" on the hose that connects to the resevoir wasnt providing enough pressure and coolant would find its way out. Just buy the smallest size hose clamp at any hardware store, pop the hose clamp on, and tighten it down well and you should have no problem.
Trainsk8 is offline   Reply With Quote
Radiator Leaking Apex123 2008 - 2012 Ninja 250R Tech Talk 7 November 9th, 2014 03:27 PM
2004 EX250 Leaking Coolant After Change drc84 1986 - 2007 Ninja 250R Tech Talk 9 May 21st, 2014 03:11 PM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Coolant leaking from the top of the engine... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 9 April 16th, 2013 06:56 PM
radiator hose burst :( leaking coolant h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 11 June 3rd, 2011 11:06 PM
