June 8th, 2012, 04:48 PM | #1 |
racer on a budget
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250, 2006 ZX6R Posts: 55
Safety wiring: oil
Drilling-up some oil-retaining bolts for safety wiring. So far I've found the following:
That last item looks sorta like a brake line, going from the top end of the motor on the brake side to the bottom end of the motor on the clutch side. On the bottom end, it appears to be attached to an oil pressure sensor or something. Do y'all safety wire that end of it? |
June 8th, 2012, 05:10 PM | #2 |
dont forget to silicone the galley bolt. i siliconed the external oil line bolts instead of safetywire. dont forget your brakes and controls.
June 10th, 2012, 07:11 AM | #3 |
June 10th, 2012, 08:39 AM | #5 | |
February 18th, 2013, 08:13 PM | #6 |
Join Date: Jul 2011 Motorcycle(s): Triumph Thruxton, Ninja 250 Posts: 148
February 18th, 2013, 08:18 PM | #7 | |
Can you post up a pic of this? Or better yet come up here and you can show me first hand. Thanks Doug |
February 19th, 2013, 10:03 PM | #8 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
Be very very careful if you are attempting to drill the oil pressure bolt (located on the right side of the engine towards the front). The bolt is hollow. I messed up my original ...
Spoke with AFM (NorCal racing club) techs and they approved using high-temp silcone over it (like you would do the brake banjo bolts).
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
February 21st, 2013, 05:42 PM | #9 |
February 22nd, 2013, 11:01 AM | #10 |
Board Member
which one is the galley bolt?
Safety wiring -- reference photos for noobs | adouglas | Ninjettes At Speed | 3 | March 22nd, 2014 03:26 PM |
Safety wiring exhaust hangers | walk_n_wind | Ninjettes At Speed | 4 | March 27th, 2013 10:23 AM |
Safety wiring: coolant | walk_n_wind | Ninjettes At Speed | 4 | June 8th, 2012 04:44 PM |
Safety wiring WARNING! | Rexbo | Ninjettes At Speed | 4 | March 24th, 2012 06:13 PM |
Safety Wire oil line banjo bolt | jasle | Ninjettes At Speed | 8 | December 29th, 2011 04:28 PM |
