Old June 8th, 2012, 04:48 PM   #1
walk_n_wind
racer on a budget
walk_n_wind's Avatar
Motorcycle(s): 2009 Ninja 250, 2006 ZX6R
Safety wiring: oil
Drilling-up some oil-retaining bolts for safety wiring. So far I've found the following:
  1. Oil filter bolt
  2. Oil drain plug
  3. A second oil drain plug (?)
  4. Oil filler cap
  5. Oil line from top end to bottom end
That last item looks sorta like a brake line, going from the top end of the motor on the brake side to the bottom end of the motor on the clutch side. On the bottom end, it appears to be attached to an oil pressure sensor or something. Do y'all safety wire that end of it?
walk_n_wind is offline   Reply With Quote
Old June 8th, 2012, 05:10 PM   #2
dont forget to silicone the galley bolt. i siliconed the external oil line bolts instead of safetywire. dont forget your brakes and controls.
Old June 10th, 2012, 07:11 AM   #3
tiggen
tiggen's Avatar
Motorcycle(s): 2003 250
Yes
+1. And axles. (edit - just saw your other thread)
tiggen is offline   Reply With Quote
Old June 10th, 2012, 08:06 AM   #4
walk_n_wind
racer on a budget
Thanks for the answer, @tiggen - how do you safety wire it? What part of the oil pressure sensor setup do you drill through?
Old June 10th, 2012, 08:39 AM   #5
tiggen
tiggen's Avatar
One end of the wire is wrapped around the switch above the shoulder where you'd put the wrech, and the other is wrapped around the neck of the hose. As long as the wire is taut, the switch won't be able to back out. Not sure if that's the preferred way, but I haven't had any problems with it.
Old February 18th, 2013, 08:13 PM   #6
RacerX113
Motorcycle(s): Triumph Thruxton, Ninja 250
Alex,
I'm not sure what/where the gaily bolt is. Can you post a picture possibly?
RacerX113 is offline   Reply With Quote
Old February 18th, 2013, 08:18 PM   #7
RacerX113
Ok John,
Can you post up a pic of this? Or better yet come up here and you can show me first hand.
Thanks
Doug
Old February 19th, 2013, 10:03 PM   #8
abhijitz
Motorcycle(s): Many Two Wheels ..
Be very very careful if you are attempting to drill the oil pressure bolt (located on the right side of the engine towards the front). The bolt is hollow. I messed up my original ...
Spoke with AFM (NorCal racing club) techs and they approved using high-temp silcone over it (like you would do the brake banjo bolts).
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old February 21st, 2013, 05:42 PM   #9
tiggen
tiggen's Avatar
Originally Posted by RacerX113 View Post
Ok John,
Thanks
Doug
Check your pm's.
Old February 22nd, 2013, 11:01 AM   #10
mgentz
Board Member
which one is the galley bolt?
Safety wiring -- reference photos for noobs adouglas Ninjettes At Speed 3 March 22nd, 2014 03:26 PM
Safety wiring exhaust hangers walk_n_wind Ninjettes At Speed 4 March 27th, 2013 10:23 AM
Safety wiring: coolant walk_n_wind Ninjettes At Speed 4 June 8th, 2012 04:44 PM
Safety wiring WARNING! Rexbo Ninjettes At Speed 4 March 24th, 2012 06:13 PM
Safety Wire oil line banjo bolt jasle Ninjettes At Speed 8 December 29th, 2011 04:28 PM
