Old November 13th, 2012, 11:58 AM   #1
Avenged7Fold
Ninjette Noob
Avenged7Fold's Avatar
Motorcycle(s): 2004 YZF-600r ---- 2006 Kawasaki Ninja 250r
Wiring help
I work in a shifty neighborhood on night shifts, and the only way to see my bike is if a headlight is on, so i wanted to wire an led so i can see its there. How do i safely go about doing this without killing my battery or setting my bike on fire? I was thinking to either wire it to the fan, because that seems to get power even when the bike is off, or directly to the battery. Does anyone have any better ideas? Do i have to put some sort of restrictor between bulb and wire? Will it affect my battery?
Avenged7Fold is offline   Reply With Quote
Old November 13th, 2012, 02:02 PM   #2
Whiskey
Wired in to the battery with a resistor before it to prevent the 12.7/14v & higher amps from blowing it should do. The draw from a single LED should be negligible especially on a bike that's run regularly.
Or find an alarm with a LED.
Help with wiring gasguzziler 1986 - 2007 Ninja 250R Tech Talk 6 May 21st, 2014 10:57 AM
ignition wiring rabies 1986 - 2007 Ninja 250R Tech Talk 7 August 13th, 2013 08:19 AM
Wiring marc_previtera 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2013 08:20 AM
Coil wiring? expat 2008 - 2012 Ninja 250R Tech Talk 2 February 26th, 2012 07:57 PM
Wiring up for GPS headshrink 2008 - 2012 Ninja 250R Tech Talk 5 May 13th, 2009 04:20 PM
