Old June 5th, 2011, 03:02 PM   #1
Cab305
Cab305's Avatar
Motorcycle(s): Blue 10 250r
My brake pads disappeared?
Was at track day today, I knew my breaks were not new, but i din't notice how bad! I rode to the track no problem, passed inspection no problem, like I said the pads were not new by any means but they were still functional, lol. I was braking way way hard into turn 8 at Homestead, felt the back end coming up, then the front kind of loosen up the brakes felt super mushy. I came right into the pit, and sure enough metal on metal no pads at all! Luckily I didn't scratch up the rotor because I came into pit right away.
Bad news, had to ride all the way home 30+ miles with no front brakes. Well, I lucked out big time because I only had to come to a complete stop 3 times total. lol
Shopping cart: High performance break pads, steel braided lines.
Cab305 is offline   Reply With Quote
Old June 5th, 2011, 03:07 PM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
You need a checklist for trackdays.
Brakes are fairly cheap. Breaks can be expensive.
I can't believe you ride to the track! How do you get your "stuff" there?
Old June 5th, 2011, 03:24 PM   #3
Cab305
Cab305's Avatar
Lol, yes indeed.
Had no choice, no truck, no trailer, no ride. Plus the finances are tight didn't want to rent u-haul again (too expensive last time). So I drove a few things to different people on saturday, then just packed up the rest + lots and lots of fluids into a bigass backpack. Did all the prep (removed turn signals, taped up lights, etc...) at the track during novice meeting. (I know the drill already)
Like i said, riding home with no brakes was doo doo, so it's an extra incentive not to wreck.
Old June 6th, 2011, 05:47 AM   #4
Bueller999
Oldie but a goodie
Bueller999's Avatar
Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC
You may not have had the tools to do a swap but you could have swapped out the rears to the front to get you home.
ABRacing
Bueller999 is offline   Reply With Quote
Old June 6th, 2011, 05:50 AM   #5
tiggen
tiggen's Avatar
Motorcycle(s): 2003 250
Were they stock pads? A buddy I pitted with about six weeks ago had the rear brake pad delaminate from the metal backing. Still had plenty of life left, it just fell apart. This was on an old gen, don't know what year, but I think they are the same stock pads.
tiggen is offline   Reply With Quote
Old June 6th, 2011, 03:19 PM   #6
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
#1 on my check list everytime I go to the track is to check the pads. I swap them every 6 or so track days.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old June 6th, 2011, 09:32 PM   #7
Kawi_LA
Motorcycle(s): 2009 Kawi 250r
really?!? every 6 or so trackdays
i've been racing the ninja for 2 years now and have only switched out the brake pads once, very recently, and only because i upgraded them. the ones that came off still have plenty of life and are kept as an extra set just in case now. i definitely agree about checking everything like brake pads before you hit the track, but every 6 track days is just over kill. not to mention, its a ninja 250!!! there really shouldn't be that much hard braking going on.
Kawi_LA is offline   Reply With Quote
Old June 6th, 2011, 09:44 PM   #8
ztrack157
The Sportisi Master
ztrack157's Avatar
I'm a vesrah distributor so I can get away with it. Bare in mind my typical track day logs more miles than others. I also said or so track days. Its not always 6 i go thru about 4 sets per year. They can still have life on the pads but not brake as efficiently.
Old June 6th, 2011, 11:35 PM   #9
Cab305
Cab305's Avatar
I thought they had a little more life. They were the stock, 7 months old. I've only used them for one other track day, and I don't ride very often, maybe 1 or 2 times a week, and not aggressive at all.
They felt fine for the first 3 sessions (plus the ride to track), then had that weird thing happen half way through the fourth session. I was going to call on you tomorrow ztrack, need to inquire about a couple of items. Mainly the Vesrah pads, at least 2 sets. Do you have any predator rear sets in stock?
Also the front spring tensioners.
Thanks
Old June 8th, 2011, 05:31 AM   #10
My rear brake ran out of material unexpectedly before 7K miles when I do the majority of my braking on the front. I pretty much took it straight to a dealer a few miles away and only used my front brake but the damage was done. At 20K miles a service tech told me that the rear rotor needed to be replaced ASAP because of abnormal wear caused by metal-on-metal contact. Sure enough, you can feel a wave of concentric circular rings worn into it when the front is perfectly flat.
They are different.
Old June 8th, 2011, 07:11 AM   #11
tiggen
tiggen's Avatar
Originally Posted by CZroe View Post
They are different.
Yeah, I checked. I was confusing that with the fact that they are the same front and rear, per each bike.
Old June 8th, 2011, 07:12 AM   #12
tiggen
tiggen's Avatar
So what do you do with all those old pads? I need a set for my rear caliper.
Old June 10th, 2011, 09:13 PM   #13
ztrack157
The Sportisi Master
ztrack157's Avatar
Normally sell them on craigslist for $15.
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Brake pads Jiggyfly Ninjettes At Speed 30 May 19th, 2014 12:56 PM
Brake pads jgcable 1986 - 2007 Ninja 250R Tech Talk 4 April 21st, 2014 05:25 AM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
HELP - brake pads nickdeveau 1986 - 2007 Ninja 250R Tech Talk 1 March 12th, 2013 05:49 AM
