Old January 10th, 2012, 06:32 AM   #1
shikikanzero
Motorcycle(s): none yet
chunks of old sealer and rust in tank?
so i patched up the damage in my fairing screw hole, no more leak, at least until my new tank from the dealer comes in. now im trying to clean out the old peeling seal job that the previous owner had the dealership do. im guessing they didnt drain out the sealer well enough and theres just huge chunks of it still in there, along with some still stuck on the inside of the tank. if it was just rust id just throw in some aquarium pellets and throw it in a dryer, but how do i get out the sealant? is there anything that can just turn it into a liquid again so i can just pour it out the petcock hole? if not im just going to cut a hole open on the top of the tank so i can stick my hand in and manually remove everything, then just JB weld the piece back on. that way i can even sandblast everything out. as long as itll last the couple of months until my new tank from the recall comes in.
shikikanzero is offline   Reply With Quote
Old January 10th, 2012, 07:16 AM   #2
Jojah17
Jojah17's Avatar
Motorcycle(s): 2008 Honja
You could try aircraft stripper. Nasty stuff though.
Jojah17 is offline   Reply With Quote
Old January 10th, 2012, 07:20 PM   #3
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
MEK dissolves Kreem, Methyl Ethyl Keytone. $10/gal at Lowes.
Use RedKote to re coat it. Can buy it at the farm supply. Made for old tractors. fills pinholes. Works like a charm. You can use the MEK to cut the RedKote and it will cure faster. Totally bad arse stuff.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Fuel tank rust removal subxero General Motorcycling Discussion 31 February 4th, 2015 09:41 AM
Tank Rust Spots UltraHarley1 2008 - 2012 Ninja 250R Tech Talk 2 June 5th, 2014 05:14 PM
Rust in the gas tank... Stingray1000 1986 - 2007 Ninja 250R Tech Talk 10 June 13th, 2012 09:35 AM
WTB: rust / hole free pregen gas tank CynicalC Items Wanted 9 April 15th, 2011 10:07 AM
[webbikeworld.com] - Caswell Fuel Tank Sealer Review Ninjette Newsbot Motorcycling News 0 May 31st, 2010 10:50 PM
