May 30th, 2009, 03:51 PM | #1 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
Nitrogen in Tires
Frist off let me say I check my tire pressure on a regular bases and it always 28 psi front and 32 psi rear. I have had my bike for about 6 months now and never put any air in the tires, which leads me to believe that the stock tires were filled with nitrogen.
Some facts about nitrogen http://www.getnitrogen.org/why/index.php The only advantage of using nitrogen vs air that I can see is you don't have to check your tire pressure as often. The only advantage of using air vs nitrogen is air is free. It cost about 8 to 10 dollars per tire to fill with nitrogen. My question is when I need to replace my tries should put nitrogen or air in the tries? Also do you have nitrogen or air in your tires? Thanks |
May 30th, 2009, 03:56 PM | #2 |
I use air... not enough advantages for me to justify filling with nitrogen. what happens when you find the pressure low or want to experiment with different pressures? It's not free and that's why they want you to use nitrogen.
BTW, your tires didn't come filled w/ nitrogen from the factory... were your valve stem caps green? |
May 30th, 2009, 04:02 PM | #3 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
It's a matter, really, of what do you have ready access to? If you can get the nitrogen fill for free, go for it. It's not really that you don't have to check your tire pressure as often. We fill aircraft tires with nitrogen, and we check pressures during every daily inspection before a flight. It's that nitrogen will be filtered to remove moisture that's relatively common with compressed air, and that nitrogen does not react with the rubber. Also, since the nitrogen molecule is larger than the molecules of the gasses that are in the air, it has a harder time escaping through the pores in the rubber and through the micro imperfections in the valve seat. (Incidently, soft plastic valve caps are essential to the system, as they form a secondary seal on purpose)
Your stock tires, I'm sure, were filled with air, if for no other reason than the cost to the dealership. Nitrogen is relatively expensive compared to compressed air and cannot be produced on site without some VERY expensive equipment, so it is usually supplied in cylinders. Good, new tires and valves will hold pressure very well, so NOT needing to air them up over a relatively short period of time is not an indication that it's nitrogen filled. Most air loss in tires is caused by poor rubber condition, poor valve condition, and poor bead seat. Nitrogen will only delay the inevitable, which is the leak, and is a total waste of money for 99% of the people who are trying to solve one of those problems (which it will not).
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
May 30th, 2009, 04:03 PM | #4 |
one disaster at a time
The air in my tires is comprised of about 78% nitrogen. So is the air in your tires.
May 30th, 2009, 04:05 PM | #5 |
MOTM - Sep '18, Feb '16
The reason you will have to refill you tires is a puncture . Air or nitrogen will hold pressure for a very long time. The main difference is that the pressure stays consistent over the entire temperature range of the tire . Also there is no moisture in nitrogen . There is a lot of moisture in air. The moisture will cause corrosion of the wheel and deteorate the rubber of the tire over time. and eat the tire pressure monitor if you had one.That said . just use air.
May 30th, 2009, 04:06 PM | #6 |
IC2(SW)
I would say No too. For the street it just worthless, and for the track you need to see the changes from cold to hot too find the correct psi.
For the track your looking for 5-7 psi gain(cold to hot). Any gain lower than that is too much psi to start off with. Gain 8-10 is too low psi starting off with. < thats almost a C/P |
May 30th, 2009, 04:08 PM | #7 |
I was the same thing I was thinking Kelly. As for the valve cap they are not green.
I think they just put the green caps on all the fast bikes. |
May 30th, 2009, 04:10 PM | #8 |
May 30th, 2009, 04:18 PM | #9 |
I think I will just fill with air when it is time for new tries then. Thanks for all your help and very fast response.
May 30th, 2009, 07:30 PM | #10 |
MOTM - Mar '13, Jun '14
I use helium. It gives you wings, or is that Red Bull?
May 30th, 2009, 07:43 PM | #11 |
i always laugh when the oil change place i take my jeep to wants to sell me nitrogen for my tires. Agree with racer x that nitro is less temperature sensitive (more stable) than air. Thats why you check tire pressure when cold. Heat of riding increases pressure more in air. That is why rear shocks of bikes are charged with nitro and not air (though not sure if250 shock has nitro charge). In the late 70s a lot of mx bikes had air shocks and air in forks. As the suspensions pounded up and down the heat built up then the air got hotter then the suspension got harsher. old pics of mx bikes will show schraeder valves on top of fork tubes. Long story short - waste of money to put nitrogen in road bike tires.
June 2nd, 2009, 08:59 AM | #12 |
Join Date: Mar 2009 Motorcycle(s): 2009 Ninja 250R SE Green Posts: 217
wow...crazy you guys get charged for the nitorgen in your tires....I asked several places about that and every dealer that sells a product that comes with nitorgen in the tires will fill them again for free, you just have to take it back to the dealer....
if your car or whatever didn't come with nitrogen and you go somewhere other then your dealer i'm not sure though. if you are out and find you need to top up the pressure though, you can put air into the tire until you are able to make it to the dealer where they will drain the tire and then refill it... |
June 2nd, 2009, 09:24 AM | #13 |
this is a quick lube place near me that charges for nigrogen.
June 2nd, 2009, 10:18 AM | #14 |
freudian slip
June 2nd, 2009, 12:35 PM | #15 | |
Tires tires tires '90 250 | mr2peak | General Motorcycling Discussion | 4 | April 4th, 2014 08:53 AM |
[webbikeworld.com] - Joe Rocket Nitrogen Gloves Review | Ninjette Newsbot | Motorcycling News | 0 | December 7th, 2012 11:50 AM |
Nitrogen in Tyres | W.Roworth | General Motorcycling Discussion | 5 | August 16th, 2012 08:24 AM |
Tires Tires Tires (ZZR) | mohns6062 | 1986 - 2007 Ninja 250R Tech Talk | 20 | June 15th, 2011 11:57 AM |
