#1 |
[motorcyclistonline] - Setting Sag | Tools 101
![]() If you ride a motorcycle with a single shock and linkage the first step in optimizing its chassis setup is dialing-in sag.If you ride a motorcycle with a single shock and linkage—whether it has slicks, knobbies or anything in between—the first step in optimizing its chassis setup is dialing-in sag. The amount the suspension settles with the rider aboard has a profound effect on suspension action and handling. Each bike varies, and recommendations are often given in the owner’s manual, but generally that figure should represent one-third of the total travel. You can handle the required measurements with an ordinary tape measure, or use one made for the job such as RaceTech’s Sag Master ($9.99 from www.racetech.com Photo Gallery: Setting Sag | Tools 101 - Motorcyclist Magazine Setting Sag | Tools 101 | Digg It | Add to del.icio.us Click here for full story...
[motorcyclistonline] - Hammered! | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | April 16th, 2012 11:10 PM |
[motorcyclistonline] - Thread Repair Tools | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | February 27th, 2012 08:20 PM |
[motorcyclistonline] - Motorcycle Brake Bleeding Tools | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | February 2nd, 2012 11:00 PM |
[motorcyclistonline] - Tire Gauges | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | January 10th, 2012 01:00 PM |
[motorcyclistonline] - Suspension Setup 101 Part I: Setting Sag | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 04:55 AM |
