Old April 26th, 2012, 09:06 AM   #1
chikenstrips
chikenstrips's Avatar
Motorcycle(s): ninja 250r
Exhaust leak
I just installed a two brothers slip on exhaust and theres a bit of a leak where it clamps on. Would "the right stuff"(rated to 450 degrees) work or do I need to use special high heat exhaust silicon?
chikenstrips is offline   Reply With Quote
Old April 26th, 2012, 10:22 AM   #2
use RTV high temp silicon gasket maker. That's what came in the package with my two brothers slip-ons when I had them, so I would assume that it would work for you as well,
Old April 26th, 2012, 12:39 PM   #3
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
I actually used an exhaust leak sealer (gooey stuff you dab on to your leak) that I got from AutoZone (paid like $3 I think) on the slight leak I have where my DanMoto sticks on...instructions said to wait 4 hours, so I've been driving the cage today...about to see if it'll work and hold up.
EthioKnight is offline   Reply With Quote
Old April 26th, 2012, 12:44 PM   #4
Pudge Ate Me
2012 Ninja 250R Green
Pudge Ate Me's Avatar
Motorcycle(s): 2012 Ninja 250R Green
Are you supposed to use a sealant when adding a slip-on? I added an MGP Growler and I just used the stuff it came with, which were 2 metal clamps.
What are the pros/cons to using a sealant and where do you use the sealant?
Where the can meets the first connector or where that connector meets the original pipe?
Pudge Ate Me is offline   Reply With Quote
Old April 26th, 2012, 12:57 PM   #5
if it leaks without sealant, use sealant. If it doesn't leak without sealant, don't worry and go for a ride.
EDIT: wow that was totally un-coherent. fixed.
Old April 26th, 2012, 01:28 PM   #6
iceknyght
Recalculating. . .
iceknyght's Avatar
Motorcycle(s): '09 250 (sold) '12 Ninja 650
I bought (probably the same) stuff but haven't put it on yet... I have a small leak on start up, but after it warms up, it goes away... So I haven't put it on yet. So far, I haven't noticed anything bad, but I have been checking after each ride to make sure...
jasontracewell.com
iceknyght is offline   Reply With Quote
Old April 26th, 2012, 01:51 PM   #7
xSean13
xSean13's Avatar
I also had a leak, after installing my danmoto exhaust, probably because it's off just a little bit where it slips on...but I just put some high temp rtv sealant on there. Gonna let it rest for another 30 mins, then test it.
Old April 26th, 2012, 05:33 PM   #8
EthioKnight
Super Noob
Just finished a 2 hour long ride...the dried paste held up pretty well (no leak @ idle) and the color kinda blends with the bronzish color of the header pipes, so all is good aesthetically as well. WIN
Old April 26th, 2012, 05:35 PM   #9
it would have been easier to take the can off, put some sealant on the inside of the joint, and then twisted the can back and forth a little as you re-installed the can. Then you could have wiped off the excess and not worried about the color at all.
Old April 26th, 2012, 05:57 PM   #10
EthioKnight
Super Noob
ahh!..now why did I not think of that?... perhaps because I'm a lazy bastard and that sounds like too much work to fix a minor leak I have a high temp black spray paint that I was planning to paint my stock can with, but never did, I might use that to paint all exposed pipes black though...hmm...
Old April 30th, 2012, 09:07 AM   #11
How do you know when you have an exhaust leak? Sound? Does it "blow?"
Old April 30th, 2012, 09:22 AM   #12
xSean13
xSean13's Avatar
1. You hear your exhaust popping when you decel.
2. You put your hand down and feel air coming out by the connections.
3. Water leaking from the exhaust connections when you first turn your bike on.
Exhaust leak on the right side Sirref 1986 - 2007 Ninja 250R Tech Talk 9 December 14th, 2014 08:01 PM
Worst Exhaust Leak Ever MarcoPolo 2008 - 2012 Ninja 250R Tech Talk 3 April 19th, 2014 10:13 PM
exhaust leak Solunatic 1986 - 2007 Ninja 250R Tech Talk 1 July 26th, 2013 04:29 AM
How much popping? (and exhaust leak) singlecoillover 2008 - 2012 Ninja 250R Tech Talk 30 May 30th, 2011 08:35 PM
Exhaust Leak Betlog 2008 - 2012 Ninja 250R Tech Talk 3 April 24th, 2010 10:27 PM
