June 28th, 2013, 11:00 AM | #1 |
Join Date: Oct 2011 Motorcycle(s): 1990 Ninja 250 Posts: 21
Pickup coil / alternator cover discrepancy
My apologies if this has already been posted but I couldn't find it
I've got a 1990 that I'm replacing the pickup coil on. I got a replacement from a 2007. So my alternator cover is off and there's a grommet for the pickup coil & alternator stator wiring to pass through the cover (I think 5 wires total). The replacement I have here has a grommet only about half the size with only the pickup coil wires in it - no alternator wires. So what's the deal with that? What bikes have two separate grommets for the two vs one for both together? The service manual I have has it either way depending on what section you're looking at so that doesn't help. The picture in the "electrical system" diagram has two grommets in different locations on the cover. The picture in the "stator coil installation" section shows them together like I see on mine. I'm looking at pickup coils taken off bikes on ebay and whatnot and there doesn't appear to be much rhyme or reason to it. Some are pictures of pickup coils only and some are combined with the alternator wiring. I guess I'm trying to see if I got the wrong one and would be best off just getting another one or what? Or hell I could probably slice my old grommet in half and then silicone it to my replacement and end up with the same thing. Thanks for any help folks! |
June 28th, 2013, 07:20 PM | #2 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Just had a look on a microfiche and it shows the generator wires and pick up coil wires in different sections. Went and had a look at mine and it seems to be two grommets glued together in the same hole. So you have the same parts, just not glued together.
June 30th, 2013, 01:52 PM | #3 |
Yeah I'm an idiot. The grommet does separate into two parts. It really didn't look like it when I looked at it. Cool! Now I sit on my butt waiting for the new cover gasket to arrive so I can replace and put it back together.
July 1st, 2013, 01:13 PM | #4 |
Cut a new gasket. I know about waiting, three weeks now for pistons/rings.
July 2nd, 2013, 01:23 AM | #6 |
With the first GPX we had, my wife was going to use it to do the course for her licence. On the weekend that the course was on, I had the bike in pieces, waiting for the clutch nut and gasket. She was not a happy camper when she got back from the course and said get that effin' bike going so I can practice. It was then that I went and bought a sheet of gasket paper and cut a gasket. the missus then spent the next week practicing on that bike, passed the second part of the course the following weekend and is now a happy camper.
Go ahead, cut the gasket and get the bike going. If you have already ordered the gasket, just use it next time you have the cover off. |
Alternator Wire Gauge | indr | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 27th, 2013 07:23 PM |
Left side alternator cover needed | jasle | Items Wanted | 4 | March 12th, 2012 07:13 PM |
Troubleshooting Battery/Alternator Help | bkh2 | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 20th, 2012 11:45 AM |
Alternator | MiniCog | 1986 - 2007 Ninja 250R Tech Talk | 3 | January 31st, 2011 08:19 PM |
Alternator output?? | gogiburn | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 25th, 2010 10:41 PM |
