February 11th, 2014, 03:31 PM | #1 |
Join Date: Jul 2012 Motorcycle(s): 2008 ninja 250ex, 1990 Yamaha Vmax 1200, 1991 Ninja 250 Go Kart Posts: 18
Headlight doesnt work
I have a 1991 Ninja 250 and the headlight doesn't even come on or work but when I switch the bright's on it comes on bright. I checked the fuses and they are all good. Does anyone know the problem that can help me fix it? Thanks!
February 11th, 2014, 03:44 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Check for voltage on the low beam at the headlight connector, if no voltage there, then check at the low/high beam switch. I'd guess it was the switch, but no substitute for proper fault isolation.
Of course, you've already checked for continuity through the bulb filament... |
February 12th, 2014, 11:53 AM | #3 |
Thanks! Ill try that!
February 12th, 2014, 12:06 PM | #4 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
First job I had, during the interview, I was given a diagram of a circuit which included a lightbulb. I was told that the light did not turn on and asked what would be the first thing I would check for towards solving this issue. Simply answer was to check the bulb, don't over think the issue. Systematically figure out the issue by starting from the obvious answer and working back.
[visordown.com] - This doesnt end as badly as I thought it would | Ninjette Newsbot | Motorcycling News | 0 | January 30th, 2014 01:50 PM |
slow rpm fall and bike doesnt want to go. | 7oxSin | 1986 - 2007 Ninja 250R Tech Talk | 16 | October 12th, 2013 08:02 AM |
Yoshi slip-on silencer doesnt fit? | newninja123 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 8th, 2012 09:22 AM |
kawasaki genuine oil filter doesnt come with O rings?! | maxwellca21 | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 17th, 2010 06:15 PM |
HID bulbs + Headlight modulator? Will it work? | lavid2002 | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 9th, 2009 07:19 PM |
