December 3rd, 2014, 05:36 PM | #1 |
Private Joker
MOTM - Mar '14
Exhaust leak on the right side
Basically I did my weekly warmup/quick neighborhood ride of my track 250 today (because I hate winterizing and find this to be a lazier approach)
and I noticed something, though I've seen it before. There is a slight leak in the right exhaust can of what I believe is fuel and some air flows through it as well. Currently I don't believe it to be severe and it feels like something a little silicone sealant can fix but I'm wondering if this can be a symptom of a bigger problem. So far I have had no issues with the bike (other than soft suspension) and don't anticipate having issues but it's better to be sure.
December 3rd, 2014, 05:59 PM | #3 |
also- gas doesnt stop aging because you use some of it. leaving old gas in there is bad even if you start it now and then... the important thing to think of is how old is that gas. +4 months? dump it into a gas can and stick it in your car.
December 3rd, 2014, 06:00 PM | #4 |
Private Joker
MOTM - Mar '14
I'm uploading a video now, because I can
also the gas is less than a month old at this point and the tank is fairly low
December 3rd, 2014, 06:04 PM | #5 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Can you feel the exhaust leak with your finger when the bike is running? (Obviously not touching the hot exhaust with one's finger). Or does it visually appear that there's been seepage in the past?
December 3rd, 2014, 06:07 PM | #6 |
Private Joker
MOTM - Mar '14
yes and yes, video will show more in a minute or so
December 3rd, 2014, 06:09 PM | #7 |
Private Joker
MOTM - Mar '14
December 3rd, 2014, 06:39 PM | #8 |
Participant
Is it a hole due to corrosion?
A budget, lazy man's fix: furnace cement. Are track tech inspectors savvy to cheesy fixes? Last futzed with by dcj13; January 27th, 2015 at 03:51 PM. |
December 3rd, 2014, 06:41 PM | #9 |
Private Joker
MOTM - Mar '14
A tech inspector at a track doesn't really look there as it's not really a safety concern
the gap appears to be a result of the exhaust mount being bent slightly out of place
December 14th, 2014, 08:01 PM | #10 |
Private Joker
MOTM - Mar '14
Found the reason for the leak
the exhaust bolts on to the passenger peg, or rather where the peg goes. The right side passenger peg was missing it's bolts so it was moving out of position slightly which created a gap. Just grabbed a few bolts from my bin and putting it where it should be stopped the leak
Worst Exhaust Leak Ever | MarcoPolo | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 19th, 2014 10:13 PM |
exhaust leak | Solunatic | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 26th, 2013 04:29 AM |
Exhaust leak | chikenstrips | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 30th, 2012 09:22 AM |
How much popping? (and exhaust leak) | singlecoillover | 2008 - 2012 Ninja 250R Tech Talk | 30 | May 30th, 2011 08:35 PM |
Exhaust Leak | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 24th, 2010 10:27 PM |
