August 16th, 2010, 12:18 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
This seems like the best place for this question.
When running at full throttle, completely pinned 11000+ rpms.
I found that when I would go full bore (pinned throttle), I would let the throttle back a bit, yet bike continued to accelerate for a split second. Have any of you experienced delayed throttle response at high rpms? Just curious, I know sometimes butterfly valves can get stuck when fully open. It startled me a couple of times as I was catching up to the bike in front faster than I had anticipated. |
August 16th, 2010, 12:25 PM | #2 |
sounds to me like your main jets could go one step leaner. what's in there now?
August 16th, 2010, 12:35 PM | #3 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
Yes I would say you could be running a little on the rich side @ WOT, by the symptoms you describe.
August 16th, 2010, 01:22 PM | #4 |
Bone stock intake, needles and exhaust @ sea level
I thought I might be a bit rich, sometimes when I'm warming her up before ride, I can smell a bit of gas in the exhaust. That's odd because I haven't touched it and I thought they came lean from factory. |
August 16th, 2010, 01:26 PM | #5 |
that's why removing the snorkel helps. The stock bikes are a bit rich on the top end (main jets) so removing the snorkel makes the 98 main jets that come stock have a bit more air so the bike runs better on the top end. If you remove the snorkel, though, the midrange runs too lean with the additional air, so you'll need to shim the carbs to compensate.
My place burned ! | Klondike1020 | Off-Topic | 22 | November 15th, 2012 09:59 AM |
[superbikeplanet.com] - Place | Ninjette Newsbot | Motorcycling News | 0 | December 24th, 2011 09:10 AM |
English 10 Language Question (Very simple question) | nickjpass | Off-Topic | 24 | September 16th, 2011 08:28 AM |
Greetings from... well, all over the place. | Hedge36 | New Members | 13 | September 30th, 2009 08:39 PM |
Nice place ya got here | dyeclan | New Members | 17 | March 31st, 2009 05:27 AM |
