Old June 13th, 2011, 09:32 AM   #1
beqwarrior
ALRE all day
beqwarrior's Avatar
Motorcycle(s): 2009 Ninja 250R SE
License plate
Cut off my fender now what is the best way to mount it? Ideas please. I have mine up with some L Brackets but is there a better way? Thanks friends- Rob
beqwarrior is offline   Reply With Quote
Old June 15th, 2011, 01:20 AM   #2
I think that's what most people use if they decide to go so far as to take off the original mounting point.
Old June 16th, 2011, 12:24 PM   #3
seanski41
Motorcycle(s): 2007 Ninja 250R
What do you do about rear turn signals?
seanski41 is offline   Reply With Quote
Old June 16th, 2011, 01:07 PM   #4
crazymater91
crazymater91's Avatar
Motorcycle(s): 1994 kawasaki ninja 250
I took my rear blinkers and stuck them in with the tail light ...
crazymater91 is offline   Reply With Quote
Old June 16th, 2011, 01:10 PM   #5
crazymater91
They make a swingarm mounting bracket you can find them on ebay
Old June 16th, 2011, 01:17 PM   #6
Yes they do, but those tend to reduce cornering clearance, and some states require your plate to be horizontal. Check with your local laws before mounting your plate that way
Old June 16th, 2011, 01:20 PM   #7
Azhyen
ninjette.org Pirate
Azhyen's Avatar
Seriously though I want to see your turn signal setup...
"She said I can't get a bike, so I dumped her."
Azhyen is offline   Reply With Quote
Old June 16th, 2011, 01:29 PM   #8
seanski41
Signed.
Kiiiinda want to do this to my bike... trying... to... resist...
Old June 16th, 2011, 01:29 PM   #9
crazymater91
True I had one for awhile but went back to a L bracket.......@ seph I git some up after work tonight
Old June 16th, 2011, 03:04 PM   #10
beqwarrior
ALRE all day
beqwarrior's Avatar
heres the new pics. i mounted it to the bolts under the brake light.
Old June 16th, 2011, 04:36 PM   #11
crazymater91
I just noticed there's some difference in years on here
Old June 16th, 2011, 05:55 PM   #12
Yes. The classic model had pods for the tun signals because it was once intended to have them there is some countries. I've seen one person drill holes in his new generation Ninja 250R's brake light to turn it into an integrated tail light but, because he didn't use white or red bulbs, it wasn't very bright after passing through the red lens/filter.
Old June 16th, 2011, 06:20 PM   #13
beqwarrior
ALRE all day
beqwarrior's Avatar
I just realized I put this in the wrong forum. Anyway It was an easy fit. Just a pain in the butt putting though lic plate bolt lights in. The wires are so short.
Old June 16th, 2011, 08:20 PM   #14
/moved to new-gen tech
Old June 16th, 2011, 08:50 PM   #15
Cazper
ninjaholic
Cazper's Avatar
I said to heck with laws and rules... I went with what I felt looked good:
Luckily for me I'm military and the bike is registered in MN while I'm living in CA... CA is one of those states that doesn't "allow" vertical plates... I haven't had anyone bother me yet and I've had many cops both civilian and military driving behind me... although I'm not a crazy rider so I'm generally not breaking any rules of the road... good luck with what you choose
09' SE Ninja 250R
$2,547.83
Old June 17th, 2011, 05:55 AM   #16
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
thats what im going with a side mount tag but on the other side of the exhaust.. i doubt i will be laying the bike down completely on its side in turns so im not to worried about clearence issues. do those hotbodies undertails not use a taillight? just the led lights underneath?
greatwhiteninja is offline   Reply With Quote
Old June 17th, 2011, 07:28 AM   #17
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
I mounted mine similar to beqwarrior's... instead of using L brackets I drilled holes in the plastic and mounted the plate up as high as possible. I had to round the plate a little to get it to fit but really like the end result and price... I only had to buy the LED tag bolts, if not for that it would be free and only took 10 minutes to chop. May not be for everyone but works for me.
Pics...
slolane is offline   Reply With Quote
Old June 17th, 2011, 07:29 AM   #18
slolane
Motorcyclist
slolane's Avatar
That looks very nice!
Old June 17th, 2011, 08:26 AM   #19
greatwhiteninja
Ridin Dirty
yeah i currently have mine like yours slolane but plan on adding the hotbodies under tail kit so then ill go side mount.. im using a led light strip under my brake light now to light up the tag..
Old June 17th, 2011, 10:10 AM   #20
HKr1
IC2(SW)
HKr1's Avatar
We just made an L bracket.
Looking up under:
Old June 17th, 2011, 05:11 PM   #21
Fly'in Ninja
Motorcycle(s): C-250R-ST
Great Ideas!!
I've been wanting to do something about the rear fender...
Fly'in Ninja is offline   Reply With Quote
License plate bulb dtyndall 2008 - 2012 Ninja 250R Tech Talk 7 February 14th, 2016 10:47 AM
License plate location Trubin General Motorcycling Discussion 10 August 16th, 2013 06:45 PM
License Plate Lighting jhunter 2008 - 2012 Ninja 250R Farkles 17 August 20th, 2012 08:39 PM
License plate bracket -kj- 2008 - 2012 Ninja 250R Tech Talk 3 February 14th, 2012 03:00 PM
License Plate Relocator Bracket Cazper 2008 - 2012 Ninja 250R Farkles 49 March 18th, 2011 11:31 PM
