Old August 29th, 2011, 09:13 AM   #1
d16soda
Motorcycle(s): 2005 Ninja 250
Help with cold start (without choke)
Hey guys, dont know if anyone remembers my vacuum issue but i got it fixed and the bike runs/idles great.
I did notice my choke cable snapped at one part by the handlebars, so i had to disconnect it. Reason being when i turned the handlebars it would engage the choke during the ride.
MY question is, what are some tricks i can do to get the bike to start without the choke, while the bike is cold. When i try i usually have one chance to start it and mess with the throttle/idle adjustment. If it dies then i have to use ether to get it started and mess with the idle adjustment for a minute while it warms a bit. Is there something i can do until i can replace the choke cable so i can start my bike cold?
d16soda is offline   Reply With Quote
Old August 29th, 2011, 10:19 AM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Other ways to avtivate the enrichener
Piece of string, index finger, . . .
GeorgeRYoung is offline   Reply With Quote
Old August 31st, 2011, 09:48 AM   #3
d16soda
yes, that is obviously an option, yet, my bike will crank and chug slowly for a second. either way, i would have to sit off the bike waiting for it to warm up so any other method besides the hoopty string method?
Old August 31st, 2011, 01:13 PM   #4
Riding it is actually the fastest way to get it to warm it up, as long as you keep the rpms in check until it's up to operating temp
Old August 31st, 2011, 01:17 PM   #5
kimboEX250
kimboEX250's Avatar
Motorcycle(s): 2002 Ninja EX250
back out the idle mixture screws 2.5 turns from seated to richen it up a little, the "choke" on these bikes are actually enrichers to dump more fuel, instead of the traditional choke of closing off air supply, i commute on the bike everyday, and have not touched the "choke" since i did it to mine, for now (that may take a weekend if you've never worked with carbs before, but you can do it, don't pay the shop) try poppin the seat off and stuff a rag into the airbox, if she fires up get on it and put it in gear and let roll and idle speed, the bike under a load may keep it running long enough to warm up a little and be good to go, hope this helps
kimboEX250 is offline   Reply With Quote
Bike doesn't need choke on start up ieathonda 1986 - 2007 Ninja 250R Tech Talk 5 April 7th, 2015 11:05 PM
Can't start w/ Choke on FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 6 September 4th, 2012 06:57 PM
Can you start when it's cold? blink General Motorcycling Discussion 18 April 14th, 2012 01:01 PM
Is full choke on a cold engine bad??? KawiKid860 General Motorcycling Discussion 6 February 4th, 2012 12:42 PM
Cant start with choke or stalls Rafalski 2008 - 2012 Ninja 250R Tech Talk 34 August 11th, 2009 12:38 AM
