#1 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
Pulling the head
The '99 was down on power at the track last year compared to the other 250's in our group (6 total) so I pulled the jugs and found huge rust pits in the cylinder walls. (it had been sitting for some time before I bought it) Replaced the pistons and cylinders with the ones from son's blown motor, and it ran much better (best it's idled since I've owned it). This spring was tuning on it and it just didn't seem right compared to the other two I have, still down on power and running a little rough. At this point I did a compression test and it was at 160 lbs. on #2 and 100 on #1, hooked the air to it and the exhaust valves where leaking so much you could feel the air coming out of the muffler and the intakes leaking enough you could hear the air coming out of the carbs. Pulled the head again and had the valves sharpened and seats ground, now it has 180 lbs. on #2 and 170 on #1 and I think it's the strongest running one of the bunch now.
#2 |
It's amazing what a good piston-cylinder seal can do. Enjoy your "new" engine.
Pulling lights for track | mikedabike64 | Ninjettes At Speed | 5 | August 28th, 2015 07:35 AM |
Strangers pulling up to you? | Kerberos | General Motorcycling Discussion | 32 | November 30th, 2011 01:59 PM |
Pulling the Ninja out after winter | Postiez | General Motorcycling Discussion | 19 | March 9th, 2010 09:35 AM |
Snorkel Pulling? | Daeldren | General Motorcycling Discussion | 8 | June 11th, 2009 06:53 AM |
[kropotkin thinks...] - Head Of Suzuki Racing: "We Came Close To Pulling Out Of MotoG | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2009 05:39 AM |
