April 24th, 2012, 02:48 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
pre gen 15t sprocket on 08+ ninja?
"OH NO its the 15t topic again"
Got a little question before i order. I can save like 40$ if the old sprocket works, where i live the shipping cost is very high for the "JT Sprockets JTF1539.15" for some reason. As far as i know, the only difference between old and new is 2 small holes on the sprocket, which the old one used for extra security. So wouldn't this one work as well: Ninja 06-07 sprocket grats. |
April 24th, 2012, 04:40 AM | #2 |
It's about 2mm thinner on one side. You can order and add a washer or two for exact alignment, but most people are OK using it without a shim/washer. There's one with all the little tabs that fits on the shaft in the Ninjette's parts fiche.
JT 15T new gen sprocket installed incorrectly?? | raytwotimes | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 19th, 2014 06:36 PM |
Sprocket comparability pre gen to new gen | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 16 | October 29th, 2013 10:22 PM |
15t Sprocket Noise | ChickenRun | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2013 12:58 PM |
FS: Pre-gen JT 14T Front Sprocket, $8 Shipped | menikmati | Motorcycle-related | 2 | February 4th, 2013 10:05 AM |
15t Sprocket Brands | lonewolf05 | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 4th, 2011 09:39 PM |
