September 21st, 2012, 06:07 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): 01 Ninja 250, 98 Honda CR80, 79 Harley Sportster Posts: 162
Air Filter/ Rear end lift..
Im looking to get a K&N Air Filter for my 01 250 what is the size i need? I do NOT want the square, ugly box shaped kind, I want the 2 cone shaped ones..
AND How would I lift my rear suspension? Thanks |
September 21st, 2012, 06:47 PM | #2 |
Join Date: Aug 2012 Motorcycle(s): 2007 Ninja 250 Posts: 181
Have you removed the airbox and rejetted?
Shhhhh, don't tell Jiggles I am using the [ you ] tag. |
September 21st, 2012, 06:55 PM | #3 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
Check the pre-gen section. I've got a thread about this same topic (lifting the bike).
As for the cone filters you will need a Dynojet jet kit and you will have to re-jet your carbs for proper performance. Otherwise your bike is gonna run like a a pile of cow ****. Also, you will need a new setup for your crankcase breather. I saw a buncha vintage Ducati's that had their breather's as just a clear tube routed somewhere it won't blow onto the motorcycle, especially its tires. |
September 22nd, 2012, 01:48 PM | #4 |
September 22nd, 2012, 05:03 PM | #6 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
Mounting a 08-12 shock on the pregen will prevent some of the sag when loaded, effectively lifting the rear. Also, it has at least a preload adjustment.
Bolt on replacement. |
September 23rd, 2012, 09:16 AM | #7 |
I have a newgen shock, it's a touch longer, and doesn't sag nearly as much as the stocker.
I also contacted Soupy's Performance for some adjustable dogbones. Instead of the standard lowering adjustable links, I had them make some shorter ones so I could lift the rear of my bike. It looks pretty good, but that's not really the important part. It turns in very quickly. Note how much space you can see between the wheel and fender here. This is with the bike on a stand, which compresses the rear a touch. It looks even more impressive when the bike is on the side-stand and there is less weight on the rear wheel: The other perk of raising the tail is ground clearance. I was within a 1/4" of the edge on my rear tire at the track, and there were no hard parts dragging at all. I had a long way to go lean-wise. |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
