April 25th, 2015, 10:54 AM | #1 |
Join Date: Apr 2015 Motorcycle(s): 2010 Kawasaki Ninja 250R Posts: 17
Complete Repaint or New Kit?
I picked up this 250r for $600 and after rebuilding the carburetor I got it to run again. The previous owner had the entire thing spray painted this weird turquoise purple. Now I have an issue: should I get some used side fairings and just repaint the bike or should I get one of those Chinese body kits? The third option would be trying to get as much of the teal spray paint off of it and get to the original color.
April 25th, 2015, 11:09 AM | #2 | |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
April 25th, 2015, 11:18 AM | #3 |
Plasti dip is another option, I'm going to try it to my spare set if fairing, once I fix some on the cracks, etc.....
https://www.dipyourcar.com/home.php
April 25th, 2015, 12:06 PM | #4 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Dip can look ok. It took 6 cans to do this white, plus about 4 cans of pearl over it. It only lasted about a season, the tank needs to be redone.
How it started:
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
April 25th, 2015, 02:41 PM | #5 |
I want to try the rustoleum paint job but I can't figure out if it needs a clear coat over it.
April 25th, 2015, 02:43 PM | #6 |
Yes it does....
April 25th, 2015, 03:35 PM | #7 |
Yes I figured as much but what is the type of clear coat that would go over Rustoleum?
April 25th, 2015, 04:29 PM | #8 |
MOTM - June '15
The $50 paint jobs don't use any clear typically. I would worry about flex in the plastics and the rustoleum.
Since hardener is added to get the nice glossy finish, it may be a bit brittle. This is just conjecture, as I was going to do that, and decided not to.
April 25th, 2015, 04:36 PM | #9 |
I've always used the krylon fusion paints, I've always had good luck with those over rustoleum, just my 2¢
April 25th, 2015, 06:37 PM | #10 |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250R Posts: 260
Why not find a local shop that does full auto body wraps and get something interesting done? Like a solid or metallic color that was never available from the factory, or even a full graphics setup, maybe something from MotoGP Moto3, the 250CC series.
If you don't like it you can always peel it off and start over, and it's most likely cheaper than a full professional paint job, and would get far better results than a rattle can. Or you could go a little bit old school and cover the bike in fake fur.... |
April 25th, 2015, 09:30 PM | #11 | |
That is amazing. |
April 25th, 2015, 11:04 PM | #12 | |
MOTM - July '15
I kinda liked it better with the mismatched colors :-) |
April 26th, 2015, 08:53 AM | #13 |
Well to throw in my two cents and my personal experiences ill tell you this much
1) The Chinese body kits of Ebay are 500 bucks either way you order them either 250 price with 250 shipping or 500 with free shipping The quality of them is 7 out of 10 I only had one hole that I had to drill out. the paint was pretty good quality and they came with a windscreen and a seat cowl so that's option 1 2) Painting yourself can be done but will cost you abit and a LOT of time. If you have experience painting with a rattle can go for it but don't expect the paint to last unless you take excellent care of it and yes clear coat probably about three coats will do 3) Wraps and professional painting can be expensive depending on where you live and how many painters / vinyl places are around your area if you want it done right you have to pay the man. I guess in summary it depends on how much time and money you have to spend @ $200 to do it yourself Paint, Sand Paper, Clear Coat, Sealer, And ALOT OF TIME $500 Complete Chinese Body Kit 2 hours of labor $??? Professional painting / wrapping not sure of cost but quality is assured. |
April 26th, 2015, 10:14 PM | #14 | |
complete Shogun Crash Kit | NJfinest50 | Motorcycle-related | 0 | November 14th, 2013 09:03 AM |
Repaint to white with blue accents | brenthedtke83 | 1986 - 2007 Ninja 250R Farkles | 22 | August 24th, 2013 02:39 AM |
Pearl White Repaint | Honko | General Motorcycling Discussion | 1 | August 11th, 2011 03:39 PM |
Having trouble finding a Koso RX-2 complete kit. | MotoStrider | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 23rd, 2011 05:54 AM |
Thinking of a repaint | JeffM | General Motorcycling Discussion | 38 | March 26th, 2010 08:21 AM |
