Old January 9th, 2013, 07:59 PM   #1
toomanyproblems
Motorcycle(s): ninja 250 03
Put on UNI pod filters now bike won't turn over
Any suggestions? Rejetting tomorrow
toomanyproblems is offline   Reply With Quote
Old January 9th, 2013, 08:35 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Rejet
AFM #676
Supersports are for n00bs
Old January 9th, 2013, 08:45 PM   #3
krolinked
Nerd
krolinked's Avatar
Motorcycle(s): Ducati Hyperstrada
Choke It.
Hard
It doesn't LOOK that steep. But you can go first...
krolinked is offline   Reply With Quote
Old January 9th, 2013, 09:28 PM   #4
DaBlue1
Long Time Rider
DaBlue1's Avatar
Did you ever fix your previous bogging problem after the re-jet?
Old January 10th, 2013, 12:15 AM   #5
toomanyproblems
We fixed the bog down no 're jet had a bad seal which led to a vacuum leak but tomorrow we are rejetting and possible shim for the needles any thoughts
Old January 10th, 2013, 05:11 AM   #6
Joshorilla
Bass Master General
Joshorilla's Avatar
There are lots of threads that cover this if you use the search feature.
Those with pod filters Dark 2013 - 2017 Ninja 300 Tech Talk 9 July 26th, 2013 08:03 PM
Does anyone use the UNI foam filters? Little Green Machine 2008 - 2012 Ninja 250R Tech Talk 14 July 24th, 2013 12:45 PM
Pod Filters coolbreeze 1986 - 2007 Ninja 250R Tech Talk 4 February 28th, 2011 07:28 PM
Uni-pod questions fivepin 1986 - 2007 Ninja 250R Tech Talk 2 August 29th, 2010 10:58 AM
Question about UNI pods\K&N air filters cbass78 1986 - 2007 Ninja 250R Tech Talk 6 March 22nd, 2009 06:28 PM
