Old May 20th, 2013, 07:28 PM   #1
Bob2010
Bob2010's Avatar
Fan overide ?
It's obvious to me lately that my bike runs different/feels different when it's warmed up. I don't do a lot of highway at all. It's all city stop and go short cruises between red lights.
How do we monitor our temps? Can I make a override for the fans so I could run them when I want?
Just curious as to what other people have to say
Thanks
2010 Red Ninja 250
2009 Black Ninja 250
Old May 20th, 2013, 07:46 PM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
for whatever reason you want to do this it seems like it would be simple enough. Disconnect fan from current circuit and then just run straight from the battery design a small circuit to fit the fans needs run circuit through a toggle switch to the fan.
You better be on the ball though with that toggle switch especially with lots of city driving, not sure exactly how prone to over heating the ninja is but seems like a risk i would not be willing to take.
Old May 20th, 2013, 09:06 PM   #3
Bob2010
Bob2010's Avatar
I could be blowing this out of proportion but reading the pregen threads, they had overheating issues.
So how would a new gen without a temp gauge tell if it was overheating? My thought was to simply override the coolant temp sensor and force the fans on. Not remove the fans from the OEM circuit.
All I'm saying is my bike starts to feel different once the fans start cycling. Wasn't sure if that's normal or not
2010 Red Ninja 250
Old May 20th, 2013, 09:28 PM   #4
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Feel different how? Maybe fan is pulling too much current?
Old May 20th, 2013, 09:50 PM   #5
jonthechron
Motorcycle(s): magHitVE
or you can get something like this, but your going to have to find the output thermal sensor on the bike and connect to the input on this board.. then you could set the fan to turn on at any temp between 2c and 140c, definitely not impossible.
http://www.ebay.com/itm/12V-12A-RELA...item1c28432432
needless to say, any fan mods you do have the pontential to burn your engine if they malfunction or are tampered with.
Ide recommend first installing a digital temp gauge to the bike before anything.
Old May 21st, 2013, 01:18 AM   #6
tubarney
Try the thermo-bob mod.
You could also install a thermostat which opens at a hotter temperature.
Ideal set-up is to have both a hotter thermostat and the thermo-bob mod. It's what I will be doing to mine.
Taking the cooling fan away is not a good idea.
Old May 21st, 2013, 02:22 AM   #7
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Get a Trail Tech.
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Anyone else a fan of Woot.com? Alex Off-Topic 9 January 3rd, 2012 03:56 PM
aluminum fan 250biker General Motorcycling Discussion 10 January 20th, 2009 12:34 AM
