Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old May 20th, 2013, 07:37 PM   #1
jonthechron
Motorcycle(s): magHitVE
NEW 2013 Ninja 250r (2nd Edition)
You think you might be looking at the Ninja 300? Think again, here it is, the new 2013 redesigned Ninja 250r. Available for purchase immediately for residents of Thailand.
Engine Four-stroke two-cylinder water-cooled.
Displacement: 249 cc.
Valve system. DOHC, 8 valves.
Cylinder size / stroke. 62.0 x 41.2 mm
Compression ratio. 11.3:1.
Transmission. 6 gears with oval turn.
Ignition. Digital
Fuel. Injection (∅ 28 mm x 2) with dual throttle.
Starter. Electric starter.
Body structure. Diamond steel pipe.
Caster angle / Trail. 27 ° / 93 mm
Tire size. 110/70-17 M / C (54S).
Rear. 140/70-17 M / C (66S).
Shock front. Shock pour les Copic size 37 mm
Shock after Gas Shock single Tractor unit and arm adjustable 5 levels.
Brake. Disk Brake Single 290 mm dual-piston calipers.
Rear brakes. Disk Brake Single 220 mm dual-piston calipers.
Length x width x height. 2010 mm x 715 mm x 1,110 mm
Wheelbase. 1,400 mm
Seat height. 785 mm
Weight. 172 kg
Capacity fuel tank. 17 liters.
http://www.kawasaki.co.th/th/motorcy..._ninja250r.asp
Old May 20th, 2013, 07:41 PM   #2
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
theyre losing the ninja-style headlight...sadface
fr1dayn1ght is offline   Reply With Quote
Old May 20th, 2013, 08:03 PM   #3
xSean13
xSean13's Avatar
The new kawi designs are fugly.
Old May 20th, 2013, 08:51 PM   #4
c-dog
c-dog's Avatar
Motorcycle(s): -
I really like the new designs. I also like the older rounded soft look of 90-00s bikes like the 250r, zx6rr, etc. The new style is geometry with angles that have small soft edges. I like the new direction of style a lot. It looks more aggressive in more high-tech way to me.
But I respect your opinion. It may not be the look for some out there.
2013 636 is so hot! I want one but I know what I would do with it and nothing but trouble....
c-dog is offline   Reply With Quote
Old May 20th, 2013, 08:55 PM   #5
I don't understand this thread. It is the same bike as the 300, but it comes with a destroked motor to take it back down to 249cc. Thailand, Japan, and a few other countries get this version instead of the 300, to better fit within tax and license categories. It was announced and released months before the 300 was released in the US.
/moved to 300 general discussion
Old June 11th, 2013, 04:33 AM   #6
xKeegan
Motorcycle(s): None yet
And then think another time, because it's a de-tuned version for certain non-US markets?
xKeegan is offline   Reply With Quote
Old June 20th, 2013, 12:45 AM   #7
jonthechron
No, it has a 249cc engine. Look at the specs.
Old June 20th, 2013, 08:41 AM   #8
warning
warning's Avatar
Motorcycle(s): A lot
It looks like a replica 300 with a 250 motor. Just sayin'.
warning is offline   Reply With Quote
Old June 20th, 2013, 05:28 PM   #9
snowbandit
Friendly Graffiti Artist
snowbandit's Avatar
Motorcycle(s): 300 SE w/ ABS
Originally Posted by warning View Post
It is a replica 300 with a 250 motor. Just sayin'.
snowbandit is offline   Reply With Quote
Old June 20th, 2013, 05:34 PM   #10
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Can this thread please die.
0 out of 1 members found this post helpful.
Old June 20th, 2013, 05:53 PM   #11
Joshorilla
Bass Master General
Joshorilla's Avatar
The engine capacity is the volume difference between the piston at the top of the stroke and the bottom of the stroke plus the gap at the top, if you were to make the stroke shorter in the same engine, you have a smaller engine capacity.
So yes, it has a 249cc engine, and yes it's the same engine as the 300 but they may have put a different crankshaft with a lesser diameter on and longer con rods.
Old June 20th, 2013, 06:04 PM   #12
KawiKid860
KawiKid860's Avatar
Wow kawasaki totally ripped off kawasaki to make the same bike just smaller
Old June 20th, 2013, 11:35 PM   #13
psych0hans
psych0hans's Avatar
Ninja 250R Special Edition beqwarrior General Motorcycling Discussion 3 April 22nd, 2011 01:41 AM
Ninja 250R Ice-Edition !!! Stavrosqq Pictures 6 February 11th, 2011 10:56 AM
[topix.net] - Nation's Biggest & Much Awaited 2nd Edition of India Leadership Awards Ninjette Newsbot Motorcycling News 0 February 4th, 2011 10:50 AM
