April 25th, 2010, 11:01 AM | #1 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
I messed up and my bike paid the price
I did a valve adjustment on my bike yesterday. I thought I did it right but I was wrong. Today I went for a ride and broke an intake valve. I am considerably bummed out. Getting it fixed is unlikely for a while. Sucks. For some reason, though, I am teetering between the idea of fixing it, or pinching pennies for a new bike. I have to clear my mind and think reasonably about what I do. But I won't be touching valves on anything again without severe trepidation.
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
April 25th, 2010, 11:07 AM | #2 |
You are sleeping
Lemme borrow your frame, Holmes. j/k..
Bummer dude. Sorry to hear it. Fix her back up again. You'll miss 'er when she's gone. I'm scared of my valve adjustment when it comes time but will give it a go anyways..
<Yeah, it's a 250. LMFAO! Weaksauce |
April 25th, 2010, 11:13 AM | #3 |
You are sleeping
Hey, you know what..
If you have it paid off already, part it out on ebay if your motor is a couple grand to fix. You could make a killing parting one of these bikes out if you have patience.
April 25th, 2010, 11:44 AM | #4 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
Oh crap!
Have you tried searching for a used motor on ebay or other local sources? |
April 25th, 2010, 11:46 AM | #5 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
+1, I've seen low mile motors on eBay for 300-400. Would be cheaper than fixing yours, plus you'd have some nice spares
April 25th, 2010, 12:04 PM | #6 |
Humble Observer
I won't be doing anything for a while.
April 25th, 2010, 12:16 PM | #7 |
Ride it like you stole it
Join Date: Jan 2010 Motorcycle(s): '09 Ninja 250R, '04 R6(sold) Posts: 362
I'm sorry to hear that.
Next time I want to adjust my own valves, I will remember this post |
April 25th, 2010, 12:46 PM | #8 |
Sorry to hear, Truong.
P.S. If you don't mind, can you share what exactly you did wrong? This might be helpful to those attempting to do their own valve adjustments in the future. |
April 25th, 2010, 01:01 PM | #9 |
MOTM - Mar '13, Jun '14
Tear that motor apart and learn from it. You have nothing to lose and everything to gain.
April 25th, 2010, 01:12 PM | #10 |
Join Date: Jun 2009 Motorcycle(s): 08 Kawi Green 250R Posts: 21
Yeah, get a service manual, tear it apart again and try to rebuild yourself. At least you can learn how to put the engine back together.
April 25th, 2010, 02:17 PM | #11 | |
Join Date: Dec 2009 Motorcycle(s): 2009 Special Edition Ninja 250 a good memory, 2011 Suzuki DL 650 the new ride Posts: 131
This is kinda scary because I also adjusted valves this weekend. I worked very slowly and carefully and I think that I did it right. I turned it over a few times by hand without spark plugs to convince myself I had replaced the timing chain correctly. It idles nicely, just like it did before. I am just heading out the door for the first ride. I hope it doesn't blow up. |
April 25th, 2010, 02:30 PM | #12 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
was the bike running ok before the valve adjustment? were you doing it as a routine maint?
I learned a long time ago if it aint broke dont fix it. I am sorry to hear its broke. |
April 25th, 2010, 03:10 PM | #13 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
People shouldn't be swayed to not do a valve adjustment. It takes a lot of patience and double/triple checking your measurements.
To be honest, it is a pain in the butt. But if you have the patience and really check yourself, you do fine. I did my valve adjustments 2k ago, and it still purrs like a kitten.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
April 25th, 2010, 04:47 PM | #14 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
OK, when you snap the head off a valve many things happen. The piston gets ruined. The head usually gets ruined. The cylinder usually gets ruined.
Here's my suggestion... Time for a big bore kit! When they bore the cylinder it should remove the scratches, it will come with new larger pistons, so you are left with the head work. Short term you might be able to have the dings in the head welded and smoothed out depending on how bad it looks. I would definitely beg, borrow, or buy the service manual and tear the motor down and have a look. If you were extremely lucky, there will be no real damage (highly unlikely). |
April 25th, 2010, 04:48 PM | #15 |
Join Date: Feb 2009 Motorcycle(s): '09 Candy Thunder Blue Ninja 250R Posts: 618
April 25th, 2010, 04:57 PM | #16 |
Truong, Sorry to hear about the valve adjustment. I`m pushing 9500mi on my bike and will have the valves adjusted at 12000. I will pony up the extra dollars and have them do it---still have two years left on the warranty.
April 25th, 2010, 09:44 PM | #17 | |
Humble Observer
April 26th, 2010, 05:52 AM | #18 | |
When I adjusted my valves last fall it took me the better part of 5 hours or so, and this was with me disassembling the bike the night before. Everything was done in tiny increments and nothing was forced or rushed. The engine still hasn't blown up yet, so I guess I did it right haha. If you're feeling up to it Truong, I say you try and rebuild the engine. The amount of confidence you'll have in yourself afterwards will be astounding. |
April 26th, 2010, 10:41 AM | #19 |
Not to draw too much attention to your condition, but it shows that you likely took extra care and yet this still happened. That's all I need to know when considering doing anything more than a oil change, brake pad/shoe replacement, or tire change. Thanks for the warning.
April 26th, 2010, 10:53 AM | #20 |
JET, I used to feel comfortable working on older Brit bikes and two strokes. These new bikes are another learning curve altogether. The only OHC machine I ever took apart was a 1956 NSU--and that was quite intimidating. On the Ninja everything is so compact. With my XXL hands, I can`t get at half the stuff. Good thing that the machine is reliable. Besides, I really don`t want to void my warranty. I do my own oil changes, brake shoe changes, air filter service, chain adjustment, cleaning, and lubing---all the easy and fun stuff.
April 26th, 2010, 10:56 AM | #21 |
It was very likely incorrect cam position when taking the measurement. To snap the head off you normally need a pretty big gap between cam and lifter (or where ever it gets measured). Took me about 4 hours on my old Katana, and it has adjustment screws. Thankfully my Buell has hydraulic lifters and doesn't really have an adjustment.
I still vote for big bore kit. |
April 26th, 2010, 11:10 AM | #22 |
Join Date: Mar 2010 Motorcycle(s): 2007 Zx10R 2009 250R Posts: 134
Man... I'm so afraid of working on valves or anything after blowing up a Mazda 626 that I just got the head rebuilt. I also did a tranmission on my 1993 ZX7R, blew that up and ended up with a used motor...... lol. I know what your feeling. My heart still races when I think of that ticking it made. *makes me feel like nails on a chalkboard*
I have always wondered with these bike where the cut off is as how much money to spend on repairing a motor vs replacing it with a used motor with 1K miles. I always believe that if I can get away with a used motor with only a few hundred miles is better than fixing up an already dead motor. Don't get me wrong, I would love to tear it down and learn the ins and outs. I have and it never turned out well. I just don't see it being cost effective when you have to factor in all the parts / work / tools and time needed to rebuild when the motors are less money. Either way, I hope you get back on the road again soon. I'm sure either route you decide to take has the same end result. To get back on and ride another day! I was able to find this. http://cgi.ebay.com/ebaymotors/08-Ka...Q5fAccessories Sometimes the trick on ebay when looking for parts for this bike is to search as EX250 instead of 250R. Good luck!
2007 Kawasaki ZX10R Red 2009 Kawasaki EX250R Special Edition |
April 26th, 2010, 12:15 PM | #23 | |
How'd you manage to blow that up? I only ask cuz the transmission on my 92 gixxer sounds like it's on its way out. My season may be ending soon |
April 26th, 2010, 10:08 PM | #24 | |
Humble Observer
As for anyone else not doing their own valve maintenance, I will not discourage it. I only know that this incident has taught me the value of absolute attention to detail, and allotting enough time in which to properly complete the job.
May 7th, 2010, 09:54 AM | #25 | |
Reason for switching the transmission was 2nd gear was popping out during acceleration and grinding. Ended up picking up a used motor in Update NY for $500 - The attempt to replace the gears ($300), tools to get the job done ($100), TOW ($250 on a SUNDAY... damn them) off the highway cost me $750. After that I just decided to find a motor rather then dumped even more money because now I had a bike that didn't run at all. = ( This was years ago maybe when I was 22.
May 7th, 2010, 12:48 PM | #26 |
Ouch! What's even worse is that your engine cost less than the towing charge.
May 7th, 2010, 09:07 PM | #27 |
Join Date: May 2010 Motorcycle(s): 2010 ninja 250r, 2009 650r Posts: 150
I,ll take this a warning for me...
New bike..What would you have paid? | hawker1693 | General Motorcycling Discussion | 8 | September 25th, 2013 06:06 AM |
[motogp.com] - Bautista: ‘We paid the price at the end’ | Ninjette Newsbot | Motorcycling News | 0 | August 19th, 2013 03:40 AM |
[sportrider - latest stories] - The Price Paid For Being Compact And Lightweight | Wh | Ninjette Newsbot | Motorcycling News | 0 | April 9th, 2012 05:50 PM |
[crash.net - MotoGP] - Hayden 'pushed luck, paid the price'. | Ninjette Newsbot | Motorcycling News | 0 | July 19th, 2009 10:50 AM |
[crash.net - MotoGP] - Stoner: We paid the price. | Ninjette Newsbot | Motorcycling News | 0 | September 14th, 2008 01:26 AM |
