Old February 7th, 2016, 10:54 AM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Front fork not moving freely after cleaning
So I am in the process of swapping spring in my front forks. And was cleaning them last night with brake part cleaner. One of the forks move pretty freely when I tip it upside down, the chrome part slides out on its own. The other side however takes a little more convincing. If i kinda tap it it will slide it. Now its not a major deal but I am curious since I have them off the bike if there is something I should be looking at? This is a 2009 with 3500 miles. So it sat quite a bit.
daverdfw is offline   Reply With Quote
Old February 7th, 2016, 05:16 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If you washed all of the oil off the seal and inner bushing, it's not uncommon to have sliding issues. If it does with with a light coat of oil, then you should fully disassemble and look for scarring or scratching on the fork tube.
Goin' fast on slow bikes!
Old February 7th, 2016, 05:16 PM   #3
daverdfw
yeah there was no scaring or anything on the fork tubes. I think because I got it really clean with lots of brake part cleaner.
Old February 7th, 2016, 05:19 PM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
It could also indicate a failing fork seal that does not have enough contact with the tube, if you still have the seals installed.
front fork caps tonybaloni 2008 - 2012 Ninja 250R Tech Talk 15 December 4th, 2015 05:39 PM
Should the rear tire spin freely? beren 1986 - 2007 Ninja 250R Tech Talk 5 October 31st, 2015 11:31 PM
Cleaning and lubing my chain, oilchange , and cleaning air filter SON1C 1986 - 2007 Ninja 250R Tech Talk 3 June 29th, 2013 05:55 AM
Front Fork Repair ? Ninjesterai 2008 - 2012 Ninja 250R Tech Talk 7 March 25th, 2012 02:08 PM
Adjustable Front Fork? Nfiniti 2008 - 2012 Ninja 250R Tech Talk 17 November 20th, 2009 12:03 PM
