Old September 18th, 2023, 12:01 PM   #1
[webbikeworld.com] - Yamaha’s 2024 WR450F
Click here for full story...
Yammie’s given us a completely reworked machine to toot the marque’s proverbial horn on their weight-to-speed ratio!
Meet the 2024 WR450F, Yamaha’s fastest 450cc enduro machine yet. If we’re talking sheer TLC, this baby features quite the docket, including the following perks:*
  • The same engine as the YZ450F, including “39mm-diameter intake valves, a new piston, connecting rod, revised bearings, optimized crank mass inertia and a dry sump oil tank with integrated generator cover” (via DirectMotocross)
  • The same drivetrain as the YZ450F, including a lighter, more compact disc spring clutch and lighter, stronger, wider main shaft gears
  • A tweaked ECU that optimized traction at low speeds and ensures prime yank at middling to fast tempi
  • A (15mm) lower, Controlled-Fill aluminum bilateral beam chassis with rigidity balance specs and engine mount points tuned specifically for the WR450F
  • A flatter, rounder seat for an uptick in riding freedom
  • Lean bodywork for more agile handling
  • KYB suspension, featuring tool-free compression damping adjustability (here is where the lower seat height and center of gravity really pay off)
  • A lightweight Lithium-lon battery
  • Lighter throttle wires, footpegs, as well as “rear wheel, hub and brake assembly”
  • 258lbs wet – a 4.4 lb. savings over the previous WR450F
  • Power Tuner app supports things like “race log recording, live bike monitoring, running time and maintenance logging, diagnosis, and more” (via Yamaha Motor)
  • A new bashplate
  • New rear fender
Click to view slideshow.We’re told that the 2024 WR450F will be hitting dealerships in a sweet*Team Yamaha Blue as of November for an MSRP of $10,199 USD.*If you’re looking for the WR250F, expect MY2024’s unit to be available in the same month, and to be priced at an MSRP of $8,999 USD.*
What do you think of Yamaha’s newest enduro competitor?
*Media sourced from DirectMotocross*
The post Yamaha’s 2024 WR450F appeared first on webBikeWorld.
[RideApart] - 2024 Yamaha WR450F Enduro Bike Gets A Complete Update For The New Year Ninjette Newsbot Motorcycling News 0 September 14th, 2023 10:31 AM
[visordown.com] - All-new WR450F part of 2024 Yamaha enduro range Ninjette Newsbot Motorcycling News 0 September 14th, 2023 02:53 AM
[webbikeworld.com] - Yamaha: 2024 TRACER® 9 GT+ is the World’s First Bike with Radar- Ninjette Newsbot Motorcycling News 0 July 26th, 2023 12:52 PM
[webbikeworld.com] - Rumor Has It: Yamaha’s Getting a Fully-Faired Triple for a 2024 Ninjette Newsbot Motorcycling News 0 December 30th, 2022 10:55 AM
[webbikeworld.com] - 2021 Yamaha WR450F [Model Overview] Ninjette Newsbot Motorcycling News 0 February 21st, 2021 05:44 AM
