#1 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
Spray paint: Close match to factory color?
So my 2007 Ninja 250 uses Candy Persimmon Red and I need spray paint in that color. I found what looks to be a website that sells OEM colors, but it's $34 for an 11 oz. spray can:
http://www.colorrite.com/product/kaw...n-red-1495.cfm Anyone know if I could at least get a close match out of cheaper options from the hardware store? |
#2 | |
A true "candy" color is a transparent tinted topcoat over a base color, usually silver. That's a pain to do consistently, so most OEM "candy" colors are not a true candy. That's good if you are trying to match a color. Many times there are "2-stage" colors that have a base and topcoat, which gets a bit tricky. With a metallic paint, spraying "wet" (heavy) give the metallic time to settle and appear darker. Too wet and it will "mottle" or "tiger-stripe". Too"dry" and the metallic is sticking up. That will make it appear lighter, but a heavy wet coat of clear can make it mottle as well. It would be a long shot to find any common paint locally that's remotely close to your color, but a good auto body paint supplier may be able to help you if you bring in a piece to match. |
#3 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Rustoleum apple red, if it's the same as the '01 color
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
#4 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 470
+1 for the Rustoleum Gloss Apple Red for an '00. It is spot on, for a non-professional painter. And, I am very critical when it comes to details.
... can't stop updating the bike! |
Spray paint track fairings | hadleyroche | General Motorcycling Discussion | 10 | May 5th, 2016 11:27 AM |
Cheap Spray Paint Experiment | Xata27 | 2008 - 2012 Ninja 250R Farkles | 10 | June 15th, 2015 06:03 AM |
High temp spray paint coming off of my headers/pipes, what next? | Monkeytofu | 1986 - 2007 Ninja 250R Farkles | 24 | December 20th, 2012 06:27 PM |
Spray can touch up paint? | Banzai | General Motorcycling Discussion | 10 | May 11th, 2010 12:35 PM |
