November 11th, 2013, 10:49 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy) Posts: 185
1990 Ninja 600R (ZX600C3) restore thread
I rescued a 1990 ZX600C for $160. Timing was perfect on everything.
She screams STOLEN, but has title. I'll get her registered under my name ASAP just to make sure. The title says 4600 miles, but unknown. Is there any way to guess on engine miles without an instrument cluster? I've taken a brief look at her and come up with these notes.
I'm going to strip her down to frame/engine to do a further inspection. Any suggestions I might not know to look for? I'm going to probably use Pod filters and Stage 3 jet kit with a 4-to-1 Vance & Hines to get around airbox issues. |
November 11th, 2013, 10:55 AM | #2 |
That's going to be a great project and at $160..... Pardon the pun but that's a steal.
November 11th, 2013, 06:31 PM | #3 |
First round:
I purchased
Vance & Hines 4-to-1 arrived today, haven't done anything with it yet. Have a significant larger pile of "**** I don't care about" than "**** I might need". Going to clean wheels and brakes tomorrow and get her registered in my name. Current total bike cost: $648 + tax/shipping Last futzed with by SabreValkyrn; November 11th, 2013 at 07:34 PM. |
November 11th, 2013, 08:35 PM | #4 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
That looks like a fun project... Good luck!!!
November 12th, 2013, 06:30 PM | #5 |
Woot woot. Title registered in my name without a hitch. At least it isn't a salvage nor stolen title.
November 12th, 2013, 07:45 PM | #6 |
Round 2
She's down to frame, wheels, engine, and coolant hoses. Starter, pods, wire harness, and ignition should be here within a week. |
November 14th, 2013, 03:37 PM | #7 |
This is great!
November 14th, 2013, 05:06 PM | #8 |
MOTM - Mar '13, Jun '14
Is it done yet?
November 14th, 2013, 05:10 PM | #9 |
November 14th, 2013, 05:43 PM | #10 |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
any new pics?
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
November 14th, 2013, 05:47 PM | #11 |
November 14th, 2013, 05:53 PM | #12 |
MSF Coach!
November 14th, 2013, 07:29 PM | #13 |
Planning to cut the tail and use Ivy's old seat to smooth out the blocky design.
My motorcycle corner. Ivy. Pod filters on carbs. I -Really- hope they don't need cleaned. Diaphragms seem very responsive. Just about every bowl screw is stripped. And wiring harness. That's going to be fun to figure out where everything goes. And the harness I took out was of no help. I'll try to get the wiring harness routed tomorrow; and hopefully get more parts tomorrow or Saturday. |
November 15th, 2013, 05:46 PM | #14 |
Starter will be here on Tuesday
Jet kit should be here tomorrow Ignition is here So, I'm going to work on carbs, valves, wiring, battery mouting, and ignition this weekend. Carbs involve removing stripped screws, cleaning, jetting, and replacing with new screws. Not looking forward to the first part. |
November 15th, 2013, 06:13 PM | #15 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
I have an old Gsxr tail and seat you can have if you want to chop it and make it fit . I paid 30 bucks for it back when I was going to street fighter an old Gsx, never used it .
Let me know if you |
November 15th, 2013, 07:45 PM | #16 |
Show us some pics I haven't decided on the tail yet; but an actual part is better than DIY with fiberglass mat, wire mesh, an d ABS cement.
November 15th, 2013, 08:01 PM | #17 |
MSF Coach!
looks good so far, you going to smooth out that tank with some body filler or anything?
also the cable management shouldn't be too rough just run it on the inside of the frame with a few zip ties.
November 15th, 2013, 08:16 PM | #18 | |
I'm not worried about the routing, just what goes where with abstract images as reference |
November 15th, 2013, 10:59 PM | #19 |
MSF Coach!
cant wait to see more! keep up the good work
November 15th, 2013, 11:49 PM | #20 |
Well. I was working on the valves. They are so incredibly too tight. Was tightening/loosening the nuts to try and raise/lower the valve. That's the locker nut btw. The valve adjust bolt is like a 2mm square.
So. My now that piston's valve bolts are extremely loose and there isn't enough thread to get the locknuts back on. Also I can't rotate the engine fully because the valve springs are bent because the vale spring bolt is so loose. Frick. Suggestions? Besides going back in time and not kriffing up? |
November 16th, 2013, 05:10 PM | #21 |
Using my super hi-tech valve adjustment device, I was able to tighten the problematic valve into submission. It's going to be a royal pain to adjust all the valves, they're super tight. I'll work on them more tomorrow.
Got the ignition replaced. That was interesting getting the old one off. The head (if there ever was one) was completely ground to a rusty and corroded circle. I was able to get the problematic ignition screws and carb screws out with a extractor bit though. Carbs are jetted and cleaned. I also have a plan for supporting them, because they won't have airbox boot support. I'll attempt valves again tomorrow and try to get the wiring harness routed and connected. |
November 17th, 2013, 05:55 PM | #22 |
Valves adjusted.
Next day:
Put everything back together, sans radiator. Laid out the wiring harness, got most things; but can't figure out what the following leads go to. I'll attempt to get the bent handlebar replaced and exhaust mounted tomorrow. I'm getting the starter on Tuesday, so hopefully I'll have her purring before Wednesday. Or be in lots of sadness and anguish because she either blows up or doesn't start. |
November 17th, 2013, 10:12 PM | #23 |
Intrepid Adventurer
So I have a tail fairing like this
W the main seat. No passenger seat or cover Srad Gsxr http://www.ebay.co.uk/bhp/suzuki-gsxr-750-srad-fairing |
November 17th, 2013, 10:39 PM | #24 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Hey at least they aren't shim under bucket valves haha. My CBR quit starting when it was less than ~70 degrees out and after replacing, checking and adjusting all sorts of FI and electronic stuff that never fixed it, I finally checked the valves and all 8 intakes were so tight they had almost no clearance. My smallest feeler gauge wouldn't fit in a few so I had to guess on what shim size and ended up having to go back and readjust them. Had the cams out 3 times... it wasn't fun. She runs like a top now and it's sooo rewarding knowing the work I put into her fixed all of the problems.
November 17th, 2013, 10:43 PM | #25 |
November 17th, 2013, 11:04 PM | #26 |
November 18th, 2013, 09:23 AM | #27 |
Intrepid Adventurer
Srad tail looks nice with a cowl
But that's my opinion It ain't blocky? Just big http://ensacarmexico.com/66.php?q=gsxr-750-srad |
November 18th, 2013, 10:21 AM | #28 | |
November 18th, 2013, 11:58 AM | #29 |
Intrepid Adventurer
http://www.bing.com/search?q=srad+ta...12-5&sp=-1&sk=
Maybe this is better ? I am not handy w the browser on my iPhone |
November 18th, 2013, 12:13 PM | #30 | |
November 18th, 2013, 12:43 PM | #31 |
Intrepid Adventurer
- I said you can have it
Therefore I am not selling it haha It's in storage , so I am not fetching it without good reason lol But it probably is more trouble than its worth when you can get a nice r1 race tail or something on eBay cheap. I just thought its a good tail for retro fitting onto other bikes because it is big and wide and very accommodating for fabrication from my point of view It is used and multiple colors and a tab is broken if I Remeber correctly . It's basically only good if you want to mess w it. The seat has a couple inch tear in the cover |
November 19th, 2013, 10:14 PM | #32 |
Got the exhaust hung, headers are a pain.
Electrical sorted out, mostly. The battery is sitting on two boxed by the brake pedal. There was no uncontrolled explosion, but there was no explosion either. The starter ran just fine, I presume the engine was turning as well? Carbs are definitely filled with gas. But no hint of rumble or resistance to the starter motor. I haven't checked the spark plugs yet. They're a PitA to get out, but it's either them or ignition coils/ignitor, right? |
December 18th, 2013, 09:31 PM | #33 |
After investigating and testing over the past couple weeks (garages are cold), I'm pretty sure the starter clutch is bad.
I'm following this thread to fix it. Had to take off the exhaust and headers again. Putting headers on alone is problematic, stupid half-circle things. I've taken off the oil pan and clutch cover, stuck on the clutch nut atm. |
January 19th, 2014, 12:37 PM | #34 |
Finally got the tools together to take a crack at the Starter Clutch.
Removed coolant, exhaust, headers, oil pan, clutch, oil pump, and the starter clutch. The sprag/idler gear itself worked just fine, however; the bushing that connects to the starter clutch gear was not connected. So the starter motor was spinning, rotating an intermediary gear, but not engaging the secondary shaft. We press-fitted the gear back onto the bushing, put everything back together and same result. The starter spun viciously, but no engine rotation; we pulled off the crank case cover (left side, exposes engine bolt for manual rotation) and no rotation when starter was spinning. So. We took the exhaust, headers, oil filter, and oil pan off to take a look at the starter clutch gear; it was resting on the secondary shaft. The gear had come off of the bushing again. This seems like a bad thing. I'm pretty sure it's supposed to be a single piece. Starter motor microfiche and part number 16085. In the picture, the red circle is surrounding the bushing and starter clutch gear. The gear is sitting on a toothed portion of the secondary shaft. Yellow box contains the bushing that should be attached to the gear. As a (side?) problem, we're not getting any spark when grounding the spark plug against the frame. Is there some sort of "don't even try sparking if the engine isn't rotating" sensor? Last futzed with by SabreValkyrn; January 19th, 2014 at 12:42 PM. Reason: Added picture |
January 20th, 2014, 06:02 AM | #35 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
Engine must spin to get spark. Are you using an ignition lock cylinder and key to power up the bike?
January 20th, 2014, 10:29 AM | #36 | |
The engine is not being rotated by the starter. My guess is the dangling gear off the center shaft is sort of important. How does... things know the engine is spinning before it tries to spark? |
January 20th, 2014, 10:33 AM | #37 |
Ms. Personality
January 20th, 2014, 10:45 AM | #38 |
Where does that plug in? The wiring harness the PO had was... wire nutted and covered in eletrical tape in so many places.
I got a used wiring harness, and I think I hooked everything up correctly; but wiring diagrams are difficult to read. |
January 20th, 2014, 10:48 AM | #39 |
Ms. Personality
The actual sensor is usually on the right side of the engine cover (sitting on the bike) where you take the cap off to turn the motor over to check the timing/valves, etc..
Give me a sec and I'll check the wiring diagrams |
January 20th, 2014, 10:53 AM | #40 |
Ms. Personality
scrrerrcccchhhhh.... back up
This bike has a stator part #59026 Each time the stator passes by the pickup it creates an electrical pulse that travels through a few components and finally to the spark plug(s). |
1990 Ninja 600R Rebuild thread | theJester517 | General Motorcycling Discussion | 8 | March 31st, 2014 07:14 PM |
1986 Ninja 250r restore | JoeMcG | 1986 - 2007 Ninja 250R Farkles | 15 | March 1st, 2014 09:53 PM |
New front and rear sprockets for 1990 2007 Ninja 250 | Agustin | Motorcycle-related | 1 | June 5th, 2012 08:40 AM |
