Old August 6th, 2017, 04:02 PM   #1
mbenjamin1010
Motorcycle(s): 2011 Ninja 650R
Repair on a 650R flairing
Hope to get some suggestions on here.
**** happens. I was hauling my bike on the back of the trailer and the metal grill broke, which in return loosened up the strap. Needless to say the bike fell over on the left side. I now have damage on the flairing. What are some inexpensive options to get it fixed?
The attached photos are from after the bike ride was restrapped.
Thank you!
mbenjamin1010 is offline   Reply With Quote
Old August 6th, 2017, 04:07 PM   #2
Are there any cracks, or just gouges? If just gouges, I'd say some Bondo and paint is all it needs. If cracks, ABS cement fiberglass cloth to patch on the inside, then Bondo and paint.
Old August 6th, 2017, 04:14 PM   #3
mbenjamin1010
No cracks.
Old August 6th, 2017, 04:16 PM   #4
mbenjamin1010
Sorry for the typos. Speak to text is not working well.
The attached photos are after the bike was restrapped
Old August 6th, 2017, 04:43 PM   #5
If you've never used Bondo before, you should get someone who is good at it at least get you started. If you're experience with it, have at it. Generally, I try to make a squeegee from something like thin sheet metal bent to match the shape of the part that's getting fixed, and try to get very close to the right shape. Like for that corner on your fairing, bend the metal to match the corner radius so you can sweep along it and get the right shape easily. It takes a couple applications with sanding between them to get it to where you can't feel any irregularities. Then prime and paint.
Old August 7th, 2017, 07:31 AM   #6
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
Looks like it needs some paint. Any cracks might I suggest J-B Weld. Not only does it work, it holds under extreme temps and is $8. Make sure to smear the weld on the INSIDE of the fairing.
Edit: I see you say no cracks. Well in that case I would take it to an experienced painter and if its bothering you that bad, foot the bill.
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 7th, 2017, 08:58 AM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
Since there are no cracks, just fill in the scratches and re-paint it. There are tons of how to videos on youtube.
If it was cracked I'd say get a cheap plastic welding iron and go to town.
I use this:
https://www.harborfreight.com/80-wat...kit-60662.html
And these filler rods:
https://www.harborfreight.com/50-pie...ods-41602.html
Old August 7th, 2017, 09:13 AM   #8
A.J.
A.J.'s Avatar
I use this:
That's pretty awesome. Heard horror stories about buying things from HF. Hobo Freight I've heard it called. But then I read many people here use it and I'd trust most of you over a bunch of keyboard warriors on Facebook.
Old August 7th, 2017, 09:32 AM   #9
VaFish
VaFish's Avatar
MOTM - Jan '16
Harbor freight does have cheap stuff. If I were buying equipment for daily use in a business I would not buy it from Harbor Freight.
But I have used that plastic welding Iron to repair 3 Ninjette fairings and it is still working. But I doubt it would last long if I was in the business of plastic welding fairings every day. Also it is fairly slow to use.
Zipper Repair Help Mike K General Motorcycling Discussion 5 April 11th, 2015 02:07 PM
Fairing repair sidekick10121 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2014 04:53 AM
Plastic repair? beniblanco 2008 - 2012 Ninja 250R Tech Talk 1 February 10th, 2014 01:21 PM
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT Ninjette Newsbot Motorcycling News 0 August 12th, 2012 08:30 PM
Anyone know how to repair Fiberglass?? ichibunkid.206 Off-Topic 4 June 16th, 2011 02:29 PM
