November 24th, 2020, 07:12 PM | #1 |
[motorcycle.com] - MO Tested: Earos One Earplug Review
For almost a decade, I rode with musician’s earplugs because I liked their flat frequency response. I could hear the sounds around me the way I always do – only quieter – without the muffled, muddied sound associated with lower-tech earplugs. Now, this type of earplug is all the rage in the motorsports world, and the manufacturers are looking for ways to differentiate themselves from the rest of the earplugs out there. Earos, with their Earos One acoustic filters (what the manufacturer calls them), have found a feature that, in my testing, makes an attractive option for motorcyclists that are interested in being able to hear their surroundings and protect their hearing at the same time. The feature is that the shape of the outer body of the earplug actually holds the earplugs in place in your ear while you wear them.
Earos One, when properly inserted in your ear canal, offers 17dB+ (NRR rated) noise protection without muffling the frequency response. This allows you to hear the world around you as you normally would, just at a lower intensity. Foam plugs, the staple of motorcyclists for generations, tend to muffle the sound, making it more difficult to hear the sounds you want to hear while you ride. Earos use patented passive filtering technology to deliver the full spectrum of sound that you typically hear. Note how the outer body of the earplug fits in the natural shape of my ear to hold the Earos One in place. Included in the box are one set of Earos and two sets of flanged ear inserts. Earos claims that approximately 90% of people’s ears will be properly fit with one of the two sizes of inserts. While my right ear seals perfectly with the large insert, my left ear canal proved, as it has with many earplugs, to be a problem. With some wiggling, I am usually able to get the Earos’ flanges to seat, but it feels uncomfortably far in my ear canal. Since the flanges seem a tad longer than other earplugs I own, I decided to experiment by cutting off the flange at the narrow tip of the insert, the thought being that it would allow me to get the wider portion of the insert further in my left ear without discomfort. The result was…success! The left earplug no longer causes me discomfort, while still offering the same level of attenuation and security in my ear.* When fully seated in my ear canals, the Earos One plugs attenuate the sound with a nearly identical amount, with the same frequency response as other musician’s earplugs I have used in the past and continue to use. However, as I said earlier in this review, the killer feature of the Earos One is the way the outer body locked them in my ears – even when sliding a helmet on or off. Additionally,* the outer body makes it easier to remove the earplugs after a ride. Never once did I need to resort to using a key to nudge the earplug into a position such that I could then remove it with my fingers, as with a couple of other brands of musician’s earplugs I have tried. With good noise attenuation, a comfortable fit that stays in place, and easy removal, Earos Ones check all the boxes. You can order a set for $40. We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works. The post MO Tested: Earos One Earplug Review appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - MO Tested: Dainese Misano 2 Review | Ninjette Newsbot | Motorcycling News | 0 | October 23rd, 2020 12:40 PM |
[motorcycle.com] - MO Tested: EarPeace Earplug Review | Ninjette Newsbot | Motorcycling News | 0 | May 19th, 2020 11:30 AM |
[motorcycle.com] - MO Tested: Eargasm Earplugs Review | Ninjette Newsbot | Motorcycling News | 0 | December 21st, 2018 01:25 PM |
[motorcycle.com] - MO Tested: SW-MOTECH Centerstand Review | Ninjette Newsbot | Motorcycling News | 0 | June 22nd, 2017 09:31 PM |
[visordown.com] - Custom earplug review: Ultimate Hearing vs Auritech | Ninjette Newsbot | Motorcycling News | 0 | August 5th, 2016 06:10 AM |
