Old April 5th, 2014, 11:26 AM   #1
Ninjinsky
Ninjinsky's Avatar
Exclamation Keep your rockers square
Just a word of warning when reassembling valvegear. Make sure all the rockers are nicely hooked over the valve heads with an 'ear' each side. It's hard to see but make the effort.
It is easy to get wrong because if it is off and sitting on the spring plate the clearance is still okay and the bike runs normally.
However a few miles on you get an odd knocking and when you open it up you find the edge of the cam has destroyed the rocker surface, Expensive
Last futzed with by Ninjinsky; April 5th, 2014 at 01:42 PM.
Old April 5th, 2014, 11:31 AM   #2
here's a photo of a nice square rocker:
Old April 5th, 2014, 11:33 AM   #3
How do I load pictures on to this site?
Old April 5th, 2014, 02:48 PM   #4
Ninjinsky
Ninjinsky's Avatar
Thanks Alex, job done
Guess I'll need an oil and filter change as well to catch that case hardenned swarf
and to the other Alex It has always puzzled me that a pro like Bo Diddley would pose getting ready to strum the wrong side of the bridge
Old April 6th, 2014, 04:45 AM   #5
n4mwd
n4mwd's Avatar
That's the first time I've seen that happen before, but I'd say that if that's the only thing that happened then you should consider yourself lucky because usually when there is a rocker failure, it is much more catastrophic than that. See my blog below for more info on what usually happens with rocker failures.
My Ninja Blog
Old April 6th, 2014, 05:43 AM   #6
Ninjinsky
Ninjinsky's Avatar
Yep, I'm lucky, Its only £40 and a week off the road. No broken ears, even after the trauma. I just missed it on reassembly, middle front which is the hardest to see.
As I said the worst of it is that there are no symptoms initially it all seems to run sweet and quiet. So you cane it up to 12k with the grin of a fool on your face little knowing the discrete carnage taking place with every revolution.
As well as oil and filter I am thinking in the circumstances a magnetic drain plug.
http://www.louis-moto.co.uk/index.ph...nr_gr=10002912
Old July 29th, 2014, 03:25 AM   #7
Ninjinsky
Ninjinsky's Avatar
ps Its flushed and running fine and a magnetic plug fitted.
Funny how I only joined in April but I feel like I have been here for years
[motorcyclemonster] - Charlotte, NC - Cyclemania: Mods vs Rockers III May 31 thru Jun Ninjette Newsbot Motorcycling News 0 May 5th, 2014 09:40 PM
[motorcyclemonster] - Minneapolis, MN - Rockers Spring Social May 17, 2014 Ninjette Newsbot Motorcycling News 0 April 30th, 2014 03:30 PM
[motorcycle-usa.com] - Mods vs Rockers Chicago Rally 2013 Ninjette Newsbot Motorcycling News 0 June 8th, 2013 01:10 PM
[motorcyclistonline] - Rockers' Motorcycles Added to Classic California Sale Ninjette Newsbot Motorcycling News 0 November 3rd, 2011 04:30 PM
[topix.net] - Mods vs. Rockers Chicago Rally Ninjette Newsbot Motorcycling News 0 August 3rd, 2011 11:50 PM
