Old October 27th, 2015, 06:57 PM   #1
Arrow What is Thread Galling?
"Thread galling occurs during installation when pressure and friction cause bolt threads to seize to the threads of a nut or tapped hole. It is also known as "cold welding".
Once a fastener has seized up from galling it is typically impossible to remove without cutting the bolt or splitting the nut.
Stainless, aluminum, and titanium fasteners form thin protective oxide films on their exposed surfaces that prevent corrosion. In addition, this coating reduces friction and prevents direct metal to metal contact during fastening.
The protective oxide film can be rubbed or scraped off under the pressure and movement of the fastener being tightened. When this happens these relatively soft metals come into direct contact. Friction increases and the chance of galling increases significantly."
Read full article here:
https://www.boltdepot.com/fastener-i...d-galling.aspx
Old October 28th, 2015, 05:54 PM   #2
Jasonm163
Motorcycle(s): 2015 Ninja 300 ABS
Very good. Many younger members without much mechanical background may not have understood this concept. I like these posts you make.
Jasonm163 is offline   Reply With Quote
Old October 28th, 2015, 10:33 PM   #3
Kevin1956
Kevin1956's Avatar
Cheap precaution, about $12.00 a can from a good auto parts store. Apply it to the threads with the included brush. Marine grade is also available from boating supply shops, which would be preferable if your bike is exposed to wet weather a lot.
Kevin1956 is offline   Reply With Quote
Old October 29th, 2015, 07:47 AM   #4
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
and good remediation if precautions weren't taken:
http://www.sears.com/tekton-7-pc-3-8...=SPM2092158803
Old October 29th, 2015, 08:30 AM   #5
When I was very young, I learned from experienced mechanics to torque slowly while feeling what the metal was doing.
I did not understand the concept of avoiding over-heating or over-torquing at that time, but it saved me many headaches while I had no torque wrench.
Thank you
Old October 29th, 2015, 10:39 AM   #6
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Remember, when using anti-seize compounds you must reduce the tightening torque or you will risk breaking bolts or stripping threads. Anti-seize compounds allow much more tension in a bolt for a given amount of torque. There should be charts on google that say how much to reduce torque.
Old November 11th, 2015, 08:00 AM   #7
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Thread galling is when someone really pisses you off in a discussion on the Interwebz and you just plain lose it.
Another Clipon Thread JBinSD Ninjettes At Speed 21 December 27th, 2012 11:31 PM
Looking for old Accessory Thread, Please help Bushmaster11B 2008 - 2012 Ninja 250R Farkles 2 October 8th, 2012 05:52 PM
My Mod thread gadgetguy1288 Pictures 24 February 9th, 2012 03:21 PM
T.S.I.Y.O.O.T.P.T.R.T. - Thread! VeX Off-Topic 124 May 11th, 2009 11:33 PM
