October 28th, 2015, 05:48 PM | #1 |
Join Date: Jul 2015 Motorcycle(s): 2015 Ninja 300 ABS Posts: 56
Weekend ideas?!
Hey guys, supposed to be super crappy out this weekend and I'm looking for something small to do on my bike. Fender Elim is done and integrated tail light won't be here for another week or two. Anyone have any fun mods I could amazon prime for this weekend?!
Completely stock bike aside from the fender elim |
October 28th, 2015, 05:52 PM | #2 |
Track Clown
MOTM - Sep '15
disassemble and reassemble bike.
October 28th, 2015, 05:55 PM | #3 |
October 28th, 2015, 06:09 PM | #4 |
dirty boy
MOTM - Apr '14
shim the carbs needles
cbr rear hugger DIY rim tape fancy bar ends new levers stainless lines adjust fork preload spacers some of those can be done pretty cheap, the stainless lines and levers r about the only things that would cost much.
October 28th, 2015, 06:13 PM | #5 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Clean your room.
If you're living at your parents; they'll be thrilled! If you're married; your partner will be thrilled! If you're on your own; you can invite someone over without embarrassment! Trust me: there's bonus points you can't imagine for all of the above! Ok; I'm sitting waiting for my order and I'm bored!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
October 28th, 2015, 07:01 PM | #6 |
Track Clown
MOTM - Sep '15
Drink beer and stare at your bike.
October 28th, 2015, 07:07 PM | #7 |
n00bie to wannabie
MOTM - Nov '15
Can I change mine? Your idea is better!
October 28th, 2015, 07:13 PM | #8 |
October 28th, 2015, 07:33 PM | #9 |
Track Clown
MOTM - Sep '15
are you in mexico?
October 28th, 2015, 07:36 PM | #10 |
Track Clown
MOTM - Sep '15
you can come here and take the shock off my S1000RR and see if it will fit on my 250R.
October 28th, 2015, 07:40 PM | #11 |
October 28th, 2015, 07:41 PM | #12 | |
Do you think a 300 for a year would be dumb to move to a bike like that? |
October 28th, 2015, 07:47 PM | #13 | |
Track Clown
MOTM - Sep '15
October 28th, 2015, 07:52 PM | #14 |
October 28th, 2015, 10:25 PM | #15 |
Join Date: Feb 2012 Motorcycle(s): 2012 Ninja 250R Posts: 362
Get a countershaft sprocket that's one tooth larger, and get yourself some bike luggage. You won't regret either.
October 28th, 2015, 10:43 PM | #16 |
Certified looney toon
MOTM Jul '13, Jul '14
How are you at electronics? Install a cellphone charger?
October 29th, 2015, 05:55 AM | #17 |
Ill look into both the sprocket, phone charger, and rim tape! All seem to be good weekend ideas! Thanks
October 29th, 2015, 06:06 AM | #18 |
Fixed it for ya.
Then sit on it, practice body position and make "vroom vroom" noises. If you can park your bike where there's a TV, bonus... watch some racing.
October 29th, 2015, 06:07 AM | #19 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
Wire up a battery tender, use the BT leads for a cell phone charger.
OR you could just buy some wet weather riding gear and practice riding in the rain. |
October 29th, 2015, 06:10 AM | #20 |
Track Clown
MOTM - Sep '15
Get a solid secure stand that can lock the rear wheel in place, then watch videos on proper body position and mimic said videos.
October 29th, 2015, 06:24 AM | #21 | |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
October 29th, 2015, 07:07 AM | #22 | ||
October 29th, 2015, 07:14 AM | #23 |
EX500 full of EX250 parts
Depending on your weight, you'll probably need to install stiffer springs before you can adjust your preload to get proper sag numbers. Springs of the wrong rate won't let you get both the static and free sag measurements right at the same time.
I bought my RaceTech springs from Amazon for about $90.
October 29th, 2015, 08:25 AM | #24 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
-throttle zip tie mod
-slip on/exhaust (rejet) -air filter replacement -snorkle delete -KLEEN air system delete with block off plate -HID conversion on the low beam -http://www.mo-door.com/ install or modify your garage door opener to work off your high-beams... -Knee grip pads like stomp grips or snake skin (I prefer snake skin for a street bike). -Rear brake reservoir delete (with some proper tygon tubing) -flush mount turn signals -bar-end mirror conversion (TRG is just the best and make your own stock mirror block off plates). If you need more, let me know!
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
October 29th, 2015, 10:23 AM | #25 |
Go old school, leave the bike in the garage for a while and experience other things in life.
Might I suggest... Or go scare some fainting goats Get video so we ALL can laugh too.
October 29th, 2015, 11:41 AM | #26 |
Snipe hunting is super fun!!! You will need a net and 2 sausages, put them in the woods by a large tree and wait. You will need to wear as much yellow as possible too, the snipes can't see yellow.
Let me know if you catch any.
October 29th, 2015, 11:57 AM | #27 | |
Ninjette Lurker
Join Date: Jun 2014 Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected) Posts: 72
Highly recommended for the weekend. |
October 29th, 2015, 03:18 PM | #28 |
Hard to believe this guy's from Kentucky...
October 29th, 2015, 03:53 PM | #29 |
MOTM - Mar '13, Jun '14
Football, Baseball, F1, strip clubs, or just stay on the forum.
Any ideas? | Sdk14 | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 15th, 2014 10:39 AM |
any ideas... | Josh_kcco | 1986 - 2007 Ninja 250R Farkles | 7 | January 15th, 2014 07:52 PM |
Any Ideas? | cuz | 2008 - 2012 Ninja 250R Tech Talk | 35 | June 24th, 2013 06:35 PM |
Any ideas? | ilovejesus | 2008 - 2012 Ninja 250R Farkles | 5 | August 18th, 2012 10:56 AM |
Any Ideas?? | bigrodge8 | General Motorcycling Discussion | 12 | February 8th, 2011 06:56 PM |
